Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 30 4:51 pm)
Phil C has a bit of SW content, & Vanishing point has a BUTTLOAD. Share CG as well.
I know I have a decent Cat, but buggered if I can 'member where I found it... mebbe Share CG. I know they have other comic characters (& a purdy decent search function)
Luck w/ yr search
WARNING!
This user has been known to swear. A LOT!
If you provide a link to the DA art-it might be easier to figure out what and where they got the content.
Thanks!
Quote - Does anyone know where to get Star Wars or Black Cat from Spiderman Content? I saw someone on DA that did awesome Star Wars characters in Poser and I'm curious where that person got it. If anyone knows where I can get some content, would be greatly appreciated. Thanks.
Aph uses a ton of content form various artists. a lot of it a recognize as not being starwars specific (aside from the lightsabers, lekku etc). I think there is a lot of Alpha Seed content (RDNA) and other cool sci fi stuff. The trick is having a large stable of content to draw from. Some things you might own a whole set that you only use the boots.. or the gloves.. or just the top .. Mixing and matching makes a big difference to capturing exactly the theme you want for your outfits.
There is a some free starwars specific stuff around as mentioned already.
One thing you should be prepared for though, is that Aph puts a lot of work into her renders, I wouldnt expect to get the same results by just loading and rendering the same products.
Lightsabers have to be done in post, or they don't look right.
http://www.renderosity.com/mod/gallery/index.php?image_id=2196804&user_id=663573&np&np
I wonder if the Older lekku are still around... the folder they live in was called northwatcher but I cant remember where I got them.. They would probably look pretty good in poser 10 with subdivision... they were just a little clunky without. As much as I appreciate the work that went into the community lekku project from starsider.net.. I never really liked the result that much. Even if it is perhaps closer to the source material than the other two options I can think of
I -think- the sabers and weapons were made by J hoagland... available at vanishingpoint.. i think..
ETA: Yep!!
The Community L are very close to Star Wars Lekku. I'll admit I got used to the older version-but the images in the links are using the Community L.
And they both look much better with SubD. I use 1 on V4 and 2 on the Lekku
Quote - I wonder if the Older lekku are still around... the folder they live in was called northwatcher but I cant remember where I got them.. They would probably look pretty good in poser 10 with subdivision... they were just a little clunky without. As much as I appreciate the work that went into the community lekku project from starsider.net.. I never really liked the result that much. Even if it is perhaps closer to the source material than the other two options I can think of
Didn't PhilC make one of those ..er ... lekkus? (don't hate me, I'm just not into -wars ;))
