Bryce F.A.Q (Last Updated: 2024 Jun 26 1:13 pm)
You don't say how complex the scene is or the speed of your PC or how much ram you have.
I just changed the size of one of my scenes to 600x600, standard render settings with no anti aliasing and rendered to disk.
It has glass, metal, plastic, and steam materials and an HDRI backdrop.
This is the result.
You may have a problem with your PC or it's just a bit slow for the job.
The time it's taking does sound a bit excessive.
Thanks Stuart. That is a good looking scene you put together!! I love the name of your news paper!
Both of my machines are rather old and I do have a tough scene to chew through with lots of lights and volume materials with transparency and plenty of soft shadows which are always slow. I am at twenty percent this morning.
Free men do not ask permission to bear
arms!!
I remember the early days on my Amiga2000 with Imagine3D renders taking 4-5 days for a 640x480 render....ah the memories of when my computer gave me time to get real world stuff done, heh heh heh
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
@UVDan.
Maybe the time it's taking is correct then it just seems a hell of a long time.
@bobbystahr
I remember using Imagine3D on the Amiga, also I think a program called Sculpt 4d.
Just out of nostalgia for the Amiga days I bought a copy of Cloanto's Amiga Forever emulator for the PC. Only used it a couple of times but it brought back a lot of old memories.
XP Pro 64 could be a small part of the problem as it is Much slower than any 64 bit version of Win 7.
I turned my old XP Dual Core into a storage device with 8 HDDs, because it still works but was SO Much slower at rendering than my Win 7 machines.
I would rather
be Politically Incorrect,
Then have Politically
Correct-Incorrectness!!!
I use to try and use the "Render to Disk" feature in Bryce but the render time rather then go down would actually go up 10 times what it would have taken to just render the image the normal way. The only advantage that I have ever seen for using that feature was the ability to set the DPI resolution so that if the nucklehead that does not know how to use a 40 meg file could print with a 300 DPI resolution. I have had quite a view of my pictures published and 99% of the images that I sent the client were 72 DPI just like yours. The file itself was over 30 megs and resolution was close to 4000x3000 and thats all that really counts. If the people that continue to demand 300 DPI resolution images (and they will) are still asking for that then honestly these people should find a new job. Just my 2 cents.
Good luck on your render using that feature but I think you should be able to get the disired effect by making the image itself larger then resizing the picture after you render it especially if you are going to publish that image.
Cheers,
David
PS: Very nice picture that you're trying to render, excellent composition and lighting!
I have a scene only 600 pixels square that is stuck on 6% for about fourteen hours now. I am going to let it keep going, but I do not even have antialiasing turned on. This was just to check on the IBL lighting before I jack up the resolution to 1200 pixels square and turn on anitaliasing.
