Wed, Feb 26, 5:34 PM CST
Forum Moderators: RedPhantom
Subject: VSS loading error - anyone seen/fixed this before?
IsaoShi ( ) posted Tue, 13 August 2013 at 1:17 PM · edited Wed, 26 February 2025 at 5:25 PM
Has any VSS user / Python guru seen this error, and do you know how to fix it, please?
I have transferred my VSS scripts from my old computer (Mac OS X 10.5) to my new computer (Mac OS X 10.8). It works fine on the old computer, but on the new one, when I press the button to load the VSS scripts menu, I get this error.
I've checked in vssui.py, and there is no such character string as xc9 (or the character it represents).
I also get another error when trying to load my Matmatic script - that one is something to do with an 'incorrect magic number'. I'll cross that bridge later...
Thanks
Izi
IsaoShi ( ) posted Tue, 13 August 2013 at 2:18 PM
Never mind, I fixed it. It requires a new second line in vssui.py to declare the text encoding:-
-- coding: utf-8 --
Mod. - thread could be deleted, unless it's possible anyone else is still using VSS and gets the same problem. Your call. :)
Izi
markschum ( ) posted Tue, 13 August 2013 at 2:25 PM
/xc9 is a code for any nonprintable character or ascii code over 128.
You may have got a bad character  somehow.  Opening the file in a text editor should let you find it.
incorrect magic number is the wrong python version for a compiled script , a .pyc file.
IsaoShi ( ) posted Tue, 13 August 2013 at 3:02 PM
Thanks markschum. Armed with that knowledge, I looked at the vssui.py file again, and spotted that three full stops in the text of one menu item had been auto-"corrected" to a single '...' character. That was the culprit.
Am I correct in imagining that bagginsbill is no longer supporting VSS/Matmatic/Parmatic? I've been away such a long time...
Izi
bagginsbill ( ) posted Tue, 13 August 2013 at 5:25 PM · edited Tue, 13 August 2013 at 5:25 PM
I'm around but not playing with Poser much. I'm willing to support matmatic and VSS (within limits). I did not encounter the problem you already solved, though. I have to think your copy was edited. I don't put non-ASCII in my .py files.
As for the magic number, as each version of Poser uses a newer version of Python, you have to go get a newer matmatic. (And I have to make newer ones.)
Did you get a fresher matmatic binary? (Last addition was for P9/PP2012)
https://sites.google.com/site/bagginsbill/free-stuff/matmatic
Is P10/PP2014 yet another bump on magic number? I haven't bothered to run matmatic on my PP2014 yet.
IsaoShi ( ) posted Tue, 13 August 2013 at 6:21 PM
Hi bb, and thanks. Good to know you're still around.
Yes, my vssui.py was edited - I have my own submenu in there for VSS, Parmatic and a couple of other utilities.
I haven't upgraded - I'm still using Poser Pro 2012. But I think the last time I used Matmatic must have been with Poser Pro 2010. I'll get a fresh binary and report back later.
Izi
IsaoShi ( ) posted Thu, 15 August 2013 at 6:34 PM
Matmatic working fine with the new download.
Izi
bagginsbill ( ) posted Thu, 15 August 2013 at 8:22 PM · edited Thu, 15 August 2013 at 8:22 PM
Cool. What are you making with it? I always imagined a healthy exchange of functions which is so easy as text, but nobody ever talks about it.
