Sat, Feb 1, 10:56 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 10:44 am)
Subject: any way to procedurally blend lip line?
MistyLaraCarrara ( ) posted Sat, 17 August 2013 at 2:05 PM · edited Sat, 01 February 2025 at 10:52 AM
like an edge blend, something, to make lip matzone edges blend 'naturally looking' with face matzone?
thanks. :)
would be more fun than painting subpixels?
a nebulous thought, if like, the unwrapped uv could be saved as an obj, a very flat obj, then, do all the procedural stuff on the flattened obj, then export as a png to layer on top of the texture template, then everything would be in the right places, that's the baking thing?
LaurieA ( ) posted Sat, 17 August 2013 at 2:08 PM
Not that I'm aware. A lip mask works well tho (image).
MistyLaraCarrara ( ) posted Sat, 17 August 2013 at 3:43 PM
smiling/grimacing lips are thinner and puckery bump smoothes.  or should do.  i'm stuck ...
LaurieA ( ) posted Sat, 17 August 2013 at 4:47 PM
Um...huh?
Santel ( ) posted Sat, 17 August 2013 at 7:28 PM
you sure that was a pot of coffee hun? :)
lmckenzie ( ) posted Sun, 18 August 2013 at 4:39 PM
I think the Cat in the Hat might know a lot about that. I'm pretty sure this has been covered once and maybe BB even weighed in with a solution - which is probably a detailed treatment of what Laurie mentioned. Good luck searching.
WandW ( ) posted Sun, 18 August 2013 at 10:20 PM
Quote - I think the Cat in the Hat might know a lot about that. I'm pretty sure this has been covered once and maybe BB even weighed in with a solution - which is probably a detailed treatment of what Laurie mentioned. Good luck searching.
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3627959
andolaurina ( ) posted Sun, 18 August 2013 at 10:39 PM
Yep, this has been asked several times through the years.
There's no way to do it without a mask, per BB. But, the mask is an easy and effective solution.
My RMP Store Freebies
Poser Ambassador; Poser 11 & 12 / DS4 / Metasequoia / Silo / Zbrush / realityPaint / UVMapperPro / XD 4 / Ps CC / Fw / Ai / Painter 12 / Clip Studio Paint / Comipo / Reality 3 / Windows 10 / Units = Poser Native
cspear ( ) posted Mon, 19 August 2013 at 5:57 AM
What you're asking for is a mask; it's probably possible to produce one using procedurals, but it is much quicker to use an image.
PoserPro 11 - Units: Metres
Adobe CC 2017
