Tue, Jan 7, 12:45 AM CST
Subject: Poser10, Wardrobe Wizard Dawn Question...
Chaosophia ( ) posted Wed, 21 August 2013 at 12:16 AM · edited Tue, 07 January 2025 at 12:44 AM
Ok so I am just getting use to Poser 10 now, and have modelled out a mesh for Dawn, currently it is dynamic, so I am wondering if I get the support for the Dawn figure @ PhilC's store will using the Wardrobe Wizard make it conforming or transfer the weightmapping from Dawn to the mesh I created?
Also by doing so, with this method, could I sell or give away the conforming or weightmapped transferred item I have created using the scripts?
meatSim ( ) posted Wed, 21 August 2013 at 12:32 AM
There are a couple of commands that I'm not sure if poser 10 has..  One is the setup room and the other is 'copy joint zones from' in the figure menu.  I know it wont let you edit weightmaps but if you have the setup room you can transfer the rig to the clothing item and if you have 'copy joint zones from' you can copy dawns weightmaps as well.  What you wont be able to do is adjust or tweak the maps, so you are stuck with whatever the autotransfer gives you.  It might get crinkly at some bends but I've found dawns weights to transfer reasonably well with copy joints zones
You wouldnt need wardrobe wizard unless you need to re-shape your item to fit dawn.
I've only used the pro version since PP2010  so its hard for me to say for sure.
Chaosophia ( ) posted Wed, 21 August 2013 at 12:39 AM
Ohhhhh, ok then, I was confused on that then about wardrobe wizard.  Yes those two things are in Poser 10, so I shall try it and see if it works. If you transfer the weightmap to the clothing and have it parented to Dawn, will it bend with the movement? I ask because I have had very minimal success rigging thus far using dev rigs. I am sure it is easier than I am making it out to be, but thus far haven't found my personal nitche for it.
Chaosophia ( ) posted Wed, 21 August 2013 at 12:42 AM
Thanks for the reply I appreciate it.
meatSim ( ) posted Wed, 21 August 2013 at 2:01 AM
yes you will first have to go into the setup room and transfer the bones using a dev rig.   I think that also transfers the weights, but if it doens't look too good then try copy joint zones after and see if it looks any better
Chaosophia ( ) posted Wed, 21 August 2013 at 9:48 PM
Ok will do so on the outfit and see if it works as I hope it does. On the dev rig when placed on the outfit does it keep the rotations as the rig or will I have to reput in the rotations? Sorry if that is a newb question but rigging has been latin to me viewing the tutorials I have seen.
Chaosophia ( ) posted Wed, 21 August 2013 at 11:41 PM · edited Wed, 21 August 2013 at 11:42 PM
ok got the rig on the cloth and it looks good as in when dawn poses the clothes follow Dawn, I just have one little problem, the dress bottom splits where the leg groups differ, any idea how to fix this? Thanks for your responce, and help.
Chaosophia ( ) posted Thu, 22 August 2013 at 12:37 AM
How the rig turned out
Chaosophia ( ) posted Thu, 22 August 2013 at 1:03 AM
ok figured out what I did wrong, forgot to seperate the leg zones with the pelvis.
