Sun, Jan 26, 6:54 PM CST
Subject: Poser to Maya problem
jackhalsey ( ) posted Sun, 25 August 2013 at 5:18 PM · edited Sat, 25 January 2025 at 5:53 PM
I got a new computer running windows Ultimate 7 with 8 cores and 16 gigs memory.  It has a AMD Radeon HD 7700 card.
I installed Poser 2012 and then Maya 2012.  I created a pz3 scene in Poser and saved it.  Then went over to Maya 2012 and tried to import it.
It said "error reading file."  I checked the plug in manager and the poser fusion plugin was loaded.  I tried creating another pz3 scene and the same response.
The whole setup worked before in the other computer.  Any ideas how to fix this.
Thank you.
markschum ( ) posted Sun, 25 August 2013 at 7:32 PM
are you using file compression or extenal binary morphs ?
jackhalsey ( ) posted Sun, 25 August 2013 at 7:54 PM
I assume file compression which is that I used before as I create the scene and then click on save as then give it a name and it is saved as a pz3 file.  Its the same procedure that used to work.
Teyon ( ) posted Sun, 25 August 2013 at 8:14 PM
Try installing Maya and then Poser along with Poser Fusion and see if that works. Otherwise, contact support.
jackhalsey ( ) posted Mon, 26 August 2013 at 2:20 PM
Finally got it solved thanks everybody.
