Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 1:36 am)
Quote - What I di is model the shoe with the figure in the zero pose. Use the v4dev cr2 as the donor rig in setup (actually just hack a copy of the cr2 and then after conforming I create a pose file to set the V4 figure foot position.
basically what I need to do is: (please correct me if I'm wrong)
make the shoe .obj
save it in poser as a figure after the rigging.
hack the cr2 file with the text editor or cr2 editor to change the foot and toes rotations.
now, I'm not so sure about saving it as a figure first though
Hi, can anyone help?
I made a pair of high heel shoes in zbrush.
after adjusting to a Victoria posed for high heels, I took the shoe to the fitting room and exported back. when I conform it it rotates back, what gives? done that with another pair of normal shoes and they behave fine.
I can adjust rotation and translation to make them fit normally. the joint editor takes care of any bending and rotation that I want to fix.
using poser 2014, what are the passages to make a high heel shoe .obj conform to a figure, for example Victoria 4?
