Tue, Nov 26, 5:33 AM CST
Subject: Poser Pro 2014 Fitting Room --- really any figure?
Ragtopjohnny ( ) posted Mon, 02 September 2013 at 12:03 PM · edited Tue, 26 November 2024 at 5:23 AM
Hi everyone...
Hoping those who have this program out there can help me.
I'm upgrading to 2014 this week, and am wondeirng.  Does the fitting room really work on ANY figure?
Also, how simple is it?   Thanks -- that is a huge selling point for me.
Poser Pro 2012/3DS Max 2013/Adobe Photoshop Elements 10/Zbrush/
PC: HP Z820 Workstation, 3.30 ghz 8 core Intel Processor, 2gig nvidia Quadro, 16 gig of Ram and 2TB Hard Drive.
willyb53 ( ) posted Mon, 02 September 2013 at 12:36 PM
Any figure? Yes
Simple?  Depends on your learning curve.  it is great for tight fitting clothes, but I tend to use it for setup of items I have run through WW.
Bill
Ragtopjohnny ( ) posted Mon, 02 September 2013 at 1:35 PM
Thanks for the opinion Bill.   Glad to know it does do it to any figure.  I'm looking forward to this. 😄
ssgbryan ( ) posted Mon, 02 September 2013 at 5:25 PM
If you pick this up:
http://www.renderosity.com/mod/bcs/dawn-fitroom-helpers/100163
most of the 90 seconds you will spend converting V4 clothing to Dawn will be moving the movement morphs into the new clothing.
It literally makes converting V4 clothing to Dawn a snap.
vilters ( ) posted Tue, 03 September 2013 at 3:52 AM
The fitting room does ANY figure but it does not do ALL clothing.
For clothing to work properly i the fitting room, it has to be fully welded.
If you see welds opening up during the fitting, you know that the problem is not in the fitting room but in the clothing.
You will have to weld the clothing first, and then take that obj file back into the fitting room.
I wrote some tutorials and demonstration treads here, juist before and after release of PP2014.
And I have some over at RDNA as well.
Search for my Vilters and fitting room from about a month before release time.
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2867255&page=1
This was the main tread about the release of Poser10 and PP2014.
After the initial hop-hop, the tread is full of examples and explanations on the fitting room, startign with my Green post on apge one untill page 11. :-).
Most of it is about the fitting room.
Those should get you started.
Answers;
Any figure = YES.
All clothing = NO.
The 900+ page manual is very good to explain the fitting room.
Certainly the first 2 fitting room pages, where the manual talks about the limitations and some work arounds.
Happy Posering
vilters ( ) posted Tue, 03 September 2013 at 4:01 AM
randym77 ( ) posted Tue, 03 September 2013 at 9:25 AM
There is definitely a learning curve.  I've played around with it, but still find Wardrobe Wizard to be faster, easier, and better.  I do sometimes take an item converted via Wardrobe Wizard into the Fitting Room to tweak it a bit.
willyb53 ( ) posted Tue, 03 September 2013 at 9:30 AM
I have both the fit room helpers and the Dawn WW module.
Depending on clothes I run through WW to do the fit, and fitting room to do setup, or use the helpers first and then fitting room.  Do not settle on just one way, learn which ones will work best for the type of clothing.  pants, as an example, usually work best through WW and then fitting room to setup.
Bill
Frequency3D ( ) posted Wed, 04 September 2013 at 12:01 PM
Hi, what is WW?
Frequency Gallery  |  Frequency Store
kfox ( ) posted Wed, 04 September 2013 at 12:29 PM · edited Wed, 04 September 2013 at 12:30 PM
WW = Wardrobe Wizard by Phil Cooke. It comes with Poser Pro and will convert clothing for native figures. You can buy licenses for other figures at his site.
Frequency3D ( ) posted Wed, 04 September 2013 at 1:35 PM
Oh... thanks! :)
