Forum Moderators: wheatpenny, RedPhantom Forum Coordinators: Anim8dtoon
Freestuff F.A.Q (Last Updated: 2025 Jan 25 2:12 pm)
Welcome to the Freestuff Forum. The Freestuff Forum is intended for all freestuff related postings within our community. This is a highlight area where our membership is invited to review, announce and give feedback in greater detail on various freestuff items offered. Members can also post wishes of freestuff items they would like to see.
Notice: Links to offsite 'For Sale' items will be removed
Renderosity Free Stuff Area
Free Stuff Gallery
I accidentally left a couple of wrongly lighted frames in the loop, which spoiled the loopness, but the cylinder is the point here! :)
http://ockhamsbungalow.com/blog22/Ride-bike.swf
My python page
My ShareCG freebies
Looks fun - never had much luck with animation, but this makes me want to play with animated toonies. Thank you!
Ockham - I like your idea as well, Kona clip is very cute and quite believeable ^.^
Outdated gallery over at DeviantArt
Fics at FanFiction.net and Archive of Our Own (AO3)
Thanks everyone! -------------------------------- gendragon - like your ideas as well - especially those on on your recent diorama. -------------------------------- jonthecelt - your're right that does! -------------------------------- vilian - if you do try playing with Dork, he takes the default P3/P4 walk animations which loop nicely. Plus it's low poly and can render fast. -------------------------------- Razor42 - I pondered the opposite :) What if someone made an undulating cylinder, obviously that would really increase the rise and fall effect, would that work or just induce a form of motion sickeness?
Just thought I'd plop them over here too (they're already posted in the Poser forum in the similar thread, but in case someone missed them ;))
The idea of the rotating ground.. I used that, with simply the round ground plane in PP2014 and some displacement-grass:
And here's my test of the rotating cylinder toy:
A more belt-like shape of the road would probably look better, but this is still fun. A goode idea.
I used the Walk Designer for these two animations btw, and just chose "walk in place". The characters never move, only the ground below them :)
Thanks for reposting these here.. A more belt-like shape of the road would probably look better.. Totally agree, both for a background animation scroller and for a road like set. ..chose "walk in place". The characters never move Totally forgot about that command! I use an older version of poser when making stuff as it's less forgiving in some ways and ensures better compatibility.
I think the Walk In Place has been part of Walk Designer since its inception? I like Walk Designer because it's an easy way to both make the animation and it's tweakable. Sometimes it gives a little odd results (like the top ani, I think I selected a wrong "donor" for the walk but it came out funny so I kept it L)
I think all the native Poser figures are Walk Designer compatible. And for animations, they're also suitably low poly and easy to work with. And... I happen to like those natives, too ;)
Attached Link: http://www.sparkyworld.co.uk/3d10own.htm
The Rollin' Road - Concept & Freebie The Rollin' Road is an attempt at modelling an animation concept. Primarily designed to replicate a visual effect as seen in many manga movies and part of the end title sequence in the original Inspector Gadget cartoons. It can also be used for "Little Planet Panoranmic" style images and animations. The idea is very simple, the scenery rolls 360 degrees around the X axis for the duration of the animation. Aka it rolls, while the figure doesn't. Plus theres an option for a rear plate to move upwards to give the impression of a rising horizon, like driving up a hill. As this approach seems more suited to cartoon style animations and images, the houses and trees have been modelled in a basic 'toon/child like style with a Beano comic like pastel colouring on the houses. While personally I think the idea hasn't quite translated from 2d to 3d as well as hoped, I figure in the right hands it can be improved. So I've released this as a freebie if anyone wants to give it a whirl. As per the poser thread, any ideas on making this better would be greatfully recived. Download from the link above. 5 second YouTube clip is here... http://www.youtube.com/watch?v=G9zVg8B_1fwPinky - you left the lens cap of your mind on again.
