Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
What a totally funny idea! I recently made an animation of a figure that went round and round on the curcilar groundplane. I guess this is in a way similar. Will download it and play :D
Woopsie.. The background obj is missing :( Oh will I'll plop another background in for now... Just thought you should know :)
Well it's certainly a lot of fun. I guess, conceptual-wise, the "roll" should be a little larger for a less toon-ish effect.. but.. I like it!
I think a more oblong shape for the roll would work better. BUT then the "turn" might not work.. I dunno...
(like threads of a tank in shape)
Hah yes it is. I never noticed L
Oh well...
Here's another version where the road rolls the right way L I cant' believe I missed that... Tire animation also improved. This is a fun idea :D
TrekkieGrrrl... Like your idea of the circular groundplane, Ockham has posted a similar thing in the freebie forum thread. BTW - thanks to you and Les for the HU on the missing OBJ I'll fix that tommorow. When I upload the fixed version, I'll add a note about reversing the roll direction making it work better. As for the change of shape, as in the other thread I was pondering something similar, maybe some form of elongation? Adding or removing houses/tree and scale is easy enough, just load the model into UVmapper and assign the material for that part to a new group. Then in your modeler just move that new group or for extra copy/paste it to a new location. Your final animation is also close to what my memory thought was the effect in the Gadget Cartoon. Turns our from looking at youtube, memory plays tricks :) The actual effect is here at roughly 21.40 with the speeding police cars. http://www.youtube.com/watch?v=7BC76BSItak
Trying to make the rate of rotation match a figures walk, so that the feet don't skid on the road can be a PITA. You can add a channel and some ERC that will let you alter the rate of rotation on the fly, so that you don't need to redo the animation of the RR cylinder. This will let you adjust the rate of rotation from within any frame, and the new rate will be implemented in all frames. The normal rate of rotation will be multiplied by the value on the "X_Rot_Mult" dial. A value of 1.0 will give the normal rate of rotation as expressed on the xRotate dial, higher values will make the RR rotate faster, lower values make the RR rotate slower.
To do that, add this channel to the top of the channel stack:
valueParm X_Rot_Mult
name X_Rot_Mult
initValue 1
hidden 0
forceLimits 0
min -100000
max 100000
trackingScale 0.01
keys
static 1
k 0 1
interpStyleLocked 0
Note the 'initValue 1', and the line 'static 1', and channel value 'k 0 1'
Next add this slaving code to the xRotate channel:
rotateX xRotate
name xrot (ROLL)
initValue 0
hidden 0
forceLimits 0
min -100000
max 100000
trackingScale 0.1
keys
static 0
k 0 0
interpStyleLocked 0
valueOpTimes
NO_FIG
RollinRoad
X_Rot_Mult
There may be advantages in converting the RollinRoad into a figure. If you set the altitude of the BODY to zero, and the altitude of the cylinder so that the top of the road is zero with respect to world space, you could then scale the BODY, and the top of the road surface would remain at zero altitude.
It might be a good idea to make the RollinRoad modular, with individual houses and trees as separate props, parented to the cylinder. This would make it much more flexible, as it would be easy to add, remove, or rearrange elements to suit the purpose at hand.
I agree with comments made by others, that a larger diameter of cylinder might be an improvement.
Thanks for that Les! If anyone wants to try and do this to the model they are more than welcome. Indeed as it says in the readme, it's been designed so the community can try to improve it for everyones benefit. To separate the model into parts will be easy enough, most of the meshes have been assigned their own material groups. So it'll be a quick job to simply assign these to new groups.
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2872317
Bit of a change this week from the usual type of freebie. This time it's a freebie and a concept! Click the link above to learn more about the idea and to get the download. More importantly is any feedback you might have about how this idea could be improved. Which is why it's been released under GPU style terms for other people in the poser/3d community to have a play.Pinky - you left the lens cap of your mind on again.
