Tue, Jan 7, 8:29 PM CST
Subject: Can someone tell what I'm doing wrong, please?
tajshan ( ) posted Sat, 22 September 2001 at 8:32 PM ยท edited Mon, 06 January 2025 at 12:49 PM
Hi all. My problem is I have the male catsuit or jumpsuit, and I using photoshop and deep paint to make the textures for it. I used UVMapper (Cox's) to make the template and I change it to RGB so I make layers for. Problem is when I make my layer on top the layer is empty and Deep Paint won't read an empty layer I think. I make a layer from the background hoping this will help but it doesn't work. Any suggestions will be appreciated, thanx.
bloodsong ( ) posted Sat, 22 September 2001 at 8:45 PM
heyas; try making the template a layer that is set to multiply or darken only, over top of a background or base layer that is filled with white. then you can paint on the empty white and see the dark template lines above it.
Buddha32 ( ) posted Sun, 23 September 2001 at 12:33 PM
Deep Paint treats anything imported from Photoshop as a single image, ad disregards layers. When exported back to Photoshop, the layer will be correct, but it doesn't help if you need the stuff below your layer for a guide when painting in Deep Paint. What I do is copy the image and send the copy to Deep Paint, then I put the newly deep painted image on top of my existing image as a new layer. It's a pain in the butt to take the extra steps, but it works.
audre ( ) posted Sun, 23 September 2001 at 9:13 PM
right, you need to create you layers in deep paint, and then go to photoshop.
