Sat, Feb 1, 10:02 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 9:10 pm)
Subject: PoserPro2014 SR2 Creating hand preset weirdness...
JAG ( ) posted Thu, 12 September 2013 at 10:09 PM · edited Sat, 01 February 2025 at 10:00 PM
I just installed the SR2 and now when I click a hand preset to add to an M4 or V4 figure, the figure's morphs go wonky.  It seems to be mostly eyes, brows and shoulders.  It's as if the morphs, which are set, get magnified or multiplied by the adding of the hand preset.  Never seen this before.  You can UNDO and it will remove the hand preset as well as the morph wonkiness [it's a word...maybe].  I've also noticed you can add a hand preset...then another...and the second one doesn't seem to add to the problem.  So if you UNDO then...it removes the wonk and yet the first hand setting remains.  It's a work-around if you're having similar issues as me.
I got so annoyed, I reinstalled PoserPro2014 base and then the SR1.  Now things are back to working normally again.
Just wanted to know if anyone else has had this happen before I bother reporting the bug.
paganeagle2001 ( ) posted Fri, 13 September 2013 at 3:33 AM
Have you installed SR2.2.
http://poser.smithmicro.com/pro2014-updates.html
All the best.
Great Uncle LROG
Who honors those we love for the very life we live?, Who sends monsters to kill us?, and at the same time sings that we will never die., Who teaches us whats real?, and how to laugh at lies?, Who decides why we live and what we'll die to defend?, Who chains us?, and Who holds the key that can set us free... It's You!, You have all the weapons you need., Now Fight!
JAG ( ) posted Fri, 13 September 2013 at 7:43 PM
Hmmm...I'll give it a try...2.1 was the previous version I installed.  Must not have been the only one with serious issues...for them to toss out 2.2 so quickly.  Hope it fixes it.  Will post back here if it doesn't.
JAG ( ) posted Fri, 13 September 2013 at 8:56 PM
Nope...the SR 2.2 did not fix the problem.  Still happens.  Add a hand preset and the figure twitches and facial and shoulder morphs that are set, jump and multiply their affects.  It's just weird.  Uninstall the 2.1 and 2.2 updaters and the problem goes away.  Again, the morphs have to be turned on and these are morphs from the ++ Vic4 and Mike4 figures...nothing new that I've created myself.  Eye size and eyebrows seem to be the one that spazzes out the most.
Am I the only one here??????
jonnybode ( ) posted Fri, 13 September 2013 at 10:25 PM · edited Fri, 13 September 2013 at 10:32 PM
Hi!
Something is definitily happening, look at the shoulders on the left V4, this is after using a hand pose on the left hand. Doesnt seem to be a problem when using a pose on the right hand.
I does however seem to dissapear when rendering (with the aid of smooth polygons).
jonnybode ( ) posted Fri, 13 September 2013 at 10:50 PM · edited Fri, 13 September 2013 at 10:52 PM
Another example, it does seem to require the arm to be bend for the fenoma to occur.
ehliasys ( ) posted Mon, 16 September 2013 at 7:12 AM
My assumption is that this is more a display issue. I have that behaviour with some (not all) hand poses, too. I switch to another camera and back, and the mesh looks OK again.
jonnybode ( ) posted Mon, 16 September 2013 at 8:20 AM
After a test i agree with you, still looks kinda weird :-)
Unfortunately I cant replicate the original posters issue, I do recall some problem with hand poses in a early incarnation of PP2014 but cant remember now what it was.
ssgbryan ( ) posted Mon, 16 September 2013 at 10:35 AM
Quote - My assumption is that this is more a display issue
Dials to Single Morph breaks the movement dials of the middle 2 fingers and the neck in the DAZ Gen4 figures.  Phil is looking into it.
JAG ( ) posted Wed, 18 September 2013 at 12:53 AM
The effect does hit the shoulders...but also the eye size and the eyebrows.  I've talked with Nerd3D about it...and when I get time I'll post some more information.  I think the problem is all inter-related phenomenon.  I will run a check to see if it's render or display related.  Thanks for all the input.
JAG ( ) posted Wed, 18 September 2013 at 1:56 AM
I have run the checks that Nerd3D asked me to make and have determined the following updated information on the problem:
  1. The glitch occurs only with addition of a hand preset to the LEFT hand.  Right does not seem to cause any problems.
  2. The glitch is display oriented.  Switching cameras eliminates the displayed glitch and also it does appear in rendered image despite being visible still in display window.
JAG ( ) posted Thu, 19 September 2013 at 9:41 PM
Correcting previous post...the rendered image DOES NOT display the visible glitch in the figure's appearance.  So even if the figure looks weird, when you render, it will look fine.  So far it's apparent that the problem is display oriented but after talking with Nerd3D again, we've also figured out it's NOT a certain graphics card or computer setup that's responsible.  Smith Micro is aware of the problem but are apparently having trouble replicating the issue in order to determine the cause...and of course then a fix.
If anyone else notices something new in regards to this, please post your problem along with detailed computer and software information.  Discovering the common denominator here will be helpful in finding the cause and then a solution to the issue.
Netherworks ( ) posted Thu, 19 September 2013 at 10:49 PM
You could create a partial pose that is just a hand (save as a pose) and then compare that to a hand file and if the hand file is getting weird and the partial pose is not, then there is something up with how Poser is handling the hand files.
IK on used to do weird things with hand poses where one hand wouldn't apply properly, I think it might have been the left.  Maybe that's still the case?
JAG ( ) posted Sun, 29 September 2013 at 7:34 AM
Thanks for the additional input, but we've already determined it's a display problem affecting PoserPro2014 SR2+ - waiting now on Smith to come up with a solution on it.
