I've made Z-depth maps to use for creating bas-relief panels; I don't know if I could figure out a way to create a set of maps (like a stack of panels) which would allow for undercut shapes. I do make models in the medieval genre.
OSes: Win7Prox64, Win7Ultx64
Ahhh! "I see, said the blind man, as he picked up his hammer and saw."
That is a Z-depth bas-relief! Oh yes, Poser can generate maps to do that.
I have used Poser to generate such maps, and then used that depth map in a new Poser scene to create bas-relief. They're all over the Narnian wardrobe...
I am putting the finishing touches on my cnc now. It's a cnc router products CRP2448. It will do 24 X48 . The have a web site. They are also 1hour from where I live. I will check out the link. If you want to work together I have no problem making the larger items. Wall panels and whatever strike my fancy.
Don
I also need to ask if you want to be a part of this project. please let me know
I'd be willing to try making some scenes and creating Z-depth maps. If you have particular ideas in mind for scenes, describe them. I'll see what I can do.
Well I would like to continue with the one we have. Can you move the charaters down. So they look like they are on the ground. Remove the scroll work and add a Castle wall in the back ground.
Also need better detail on some parts. The mail on the horse is not coming through.The shield decorations are not coming through. May need to in crease the size of some of that. Could you double the size of the picture. If it is to big for here e-mail it to me.
Thank You
Don
It will take a while to work that up. Just check back periodically. I don't even know if I have the scene file which I used to make that. It was just to provide detail for a monument in another scene, and my main modeling computer -on which that was made- got blasted during a thunderstorm some time ago. But I'll have an armored knight attending a lady's horse/unicorn, and add castle walls behind them. Might help perspective if I add detailed ground/paving.
Oh, did you expand the image before saving it? It should be 1200x1200.
I can certainly make an image that's 2400x2400, but I don't think I can upload it to the forum here, so I'll probably need to e-mail that.
Quote - We need good detail but also not to small.
Yes, I'll keep in mind a balance of detail, enough to make the engraving "pop" but not so fine as to get lost by the cutting process.
I haven't found that scene file (don't know if I will), but I've begun a new scene with a more classic medieval style.
To protect yourself from spambots -which scour every forum they can- remove that e-mail address. Mods: if the edit time has expired for Don, please remove it for him.
Don, I haven't forgotten about you. In order to place the people/horse "on the ground", I need to build a ground, one which is suitable for a castle, which means a moat surrounding the castle and a road leading to the drawbridge. With some strategically chosen texturing, such a ground will give perspective to your bas-relief. Here are raw shots of the terrain, castle, and knight. I need to rough up the ground a bit. There will be a Z-depth forest beyond the perimeter (that is already finished).
I am getting into CNC woodworking. I am looking to work with someone who can create scenes and assets in a 3D program. These will then be used to cut panels and whatever from wood. What type of scenes I would like to do are Medivel town scenes. Castles and knights. My interest are Heraldry,Irish, Gaelic Celtic music. If you know how to save 3D scenes as height bump maps that would be awsome
A little about me I am 72 retired and getting into CNC as a hobby. So this will be for hobby and fun. If you like making scenes of a Medivel nature lets talk.
Thank You
Don Murphy
