Sun, Feb 16, 11:57 AM CST
Subject: relative file path syntax pointing to current folder?
MistyLaraCarrara ( ) posted Fri, 04 October 2013 at 1:18 PM · edited Fri, 22 November 2024 at 2:15 AM
i'm baking my dialed characters into original obj.
instead of putting them in the geometries folder,
is there a way to tell poser to find the obj in the current folder with the .cr2?
i want to be able to move the folder around, so i don't want to put the full path.
Thanks! :)
lesbentley ( ) posted Fri, 04 October 2013 at 2:19 PM · edited Fri, 04 October 2013 at 2:28 PM
Just use a colon (:), then the file name without a path, eg:
figureResFile :NameOf.obj
This has always worked for me. Note that there are two 'figureResFile' lines in a cr2, they both need editing.
P.S.
This also works for calling a pmd file. I suspect it would work for image maps as well, but have not tested that.
MistyLaraCarrara ( ) posted Fri, 04 October 2013 at 3:03 PM · edited Fri, 04 October 2013 at 3:05 PM
Thanks Les.  :)
Will try with the image maps, too.
It would be easier organized to keep all the files with a character together.
i find it easier to keep everything in the library, instead of hunting down pz3s
