Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 4:13 pm)
Transparency_edge should be 1 but that won't necessarily take care of it. Plug the transparency map into that as well, or it will do the wrong thing in the other direction (making the leaf fully transparent when viewed edge-wise.)
Or - set Transparency_Falloff to 0, in which case Transparency_Edge becomes irrelevant.
However - the real culprit is usually that the specular channel fires even on transparent things. This was done because the designers of the material room imagined transparency could mean "clear plastic", like a soda bottle. When, instead, you use transparency to mean "nothing here", you must also modulate the specularity so there isn't any. Plug the transparency map into Specular_Value.
If you have any other effect enabled, that, too, may need to be modulated. For example, if there is reflection in the Reflection_Color, this will be a problem. This is one of the reasons I always use the Alternate_Diffuse channel for reflection.
Attached Link: http://www.frecle.net/index.php?show=treed.about
I downloaded this free tree generator and made a sample tree.I exported the tree to wavefront OBJ and imported it to poser.
I copy pasted the textures (png files with transparent background) from the software's texture library.
The result looks like a tree made of post cards.
What do I need to tweak on the material settings to make this work?
http://img546.imageshack.us/img546/3631/yq7e.jpg
Passion is anger and love combined. So if it looks angry, give it some love!
