Sat, Jan 25, 11:46 AM CST
Subject: A Shot From My Latest Project...
DarkEdge ( ) posted Sun, 20 October 2013 at 6:25 PM · edited Fri, 17 January 2025 at 8:39 AM
Here's a shot from my latest project. The shocks, coils and wheels are fully rigged to operate as in the real world. Fleshing this out has made me want to add one more rigging detail to the front tires though...I want them to slightly rotate inward and outward along the z axis for some flex. Any thoughts and comments are welcomed.
Ragtopjohnny ( ) posted Sun, 20 October 2013 at 7:37 PM
Very cool and good job.  😄
Poser Pro 2012/3DS Max 2013/Adobe Photoshop Elements 10/Zbrush/
PC: HP Z820 Workstation, 3.30 ghz 8 core Intel Processor, 2gig nvidia Quadro, 16 gig of Ram and 2TB Hard Drive.
mrsparky ( ) posted Sun, 20 October 2013 at 9:22 PM · edited Sun, 20 October 2013 at 9:22 PM
Nicely done! Quick questions, how are you making the front wheels and suspension work? Currently Working on a semi-toon style halloween car. Only a 3rd in on the modelling so not as refined as yours:) On the WIP areas in grey can turn/rotate, areas in red are what the wheel turns on. White line will be a mock steering bar connected to a box, similar to yours. No suspension on the toon model, but curious if you'll also make that work on yours. Doing the top/bottom static, then using 2 movable cylinders inside the spring is easy enough. But I've not found a solution to making the spring 'squish' yet.
DarkEdge ( ) posted Sun, 20 October 2013 at 9:58 PM
Thanks!
Sparks, it's all done with dependent parameters, morphs and point at commands. 😄
DreamlandModels ( ) posted Sun, 20 October 2013 at 10:40 PM
Hi DarkEdge,
Excellent modeling! Have no suggestions. Rigging is fun. Learned it from Phil. Quite the brilliant man. :-)
Tom
vilters ( ) posted Mon, 21 October 2013 at 3:09 AM
That is extremely good. A work of art. Outstanding job.
DarkEdge ( ) posted Mon, 21 October 2013 at 9:04 AM
Thanks Tom and Vilters...it's totally fun!
Sa_raneth ( ) posted Mon, 21 October 2013 at 9:14 AM
great  work
