Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 3:06 am)
No, there is no such feature on the Mac. If you drop a folder to a place where there is a folder with the same name you will be prompted if you want to overwrite the folder.
To merge two folders together you need to use the DittoGUI application: http://www.ilike.co.nz/SoftwareDev/dittoGUI.html
Hope this helps.
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+:
https://plus.google.com/106625816153304163119
The
Reality Gallery: https://reality-plug-in.deviantart.com
To be complete, the "ditto" command does the job of merging and it's part of the OS. Unfortunately it's a command-line application and many people would be intimidated by it. Hence the need for the DittoGUI frontend.
Cheers.
Paolo
Tw: @preta3d
G+:
The
Not to ask for too much of your time... but...
Could you write me a paragraph or two about this to go in the FAQ so I don't give the Mac users a bum steer? Just a 1-2-3 list of the steps to go through and the commands to use.
(I don't have access to a Mac and therefore must depend on other users like you to insure my accuracy.)
No problem, I will.
Cheers.
Paolo
Tw: @preta3d
G+:
The
Let me know the format that you can use.
Can I use images or it has to be pure text?
Paolo
Tw: @preta3d
G+:
The
Not wishing to hijack the thread but just to provide other options:-
http://www.philc.net/unzip.php
Use it/don't use it.
Refer to it/don't refer to it.
Whatever is your pleasure.
That looks great Phil. Thank you for sharing it, I was not aware of this program.
Cheers.
Paolo
Tw: @preta3d
G+:
The
I've just been using Smith Micro's free Stuffit Expander utility to unzip... it handles the merging, which OS X does not do natively.
Works fine when the zip is properly compiled... i.e. runtime (and any docs) folder at the root.
With some zips, e.g. the new Daz zip format, this isn't the case... so I got the more fully featured Stuffit Archive Manager, which allows separate extraction of sub folders within a zip archive.
I use that ditto utility all the time for installing my stuff and mergin my folders.
This merging is perhaps the biggest difference when using PC compared to mac.
apart from that everything else in poser works pretty much the same.
I aim to update it about once a month. Oh, and it's free!
We have come to an issue in preparing a section of the new FAQ and I need a Mac user to clarify this...
When moving a runtime from an unpacking folder to a runtime folder, Does the MAC OS prompt the user to merge, overwrite, (anything) the new runtime folder with the old one?
On a Windows box, the OS asks if you want to merge the new folder with the old one of the same name. This is what we want. Is this the case with a MAC? If not, what messages do you get and what are the right answers to give?
Any help appreciated.
