From what I can see, the hair material has ambiant and or transluscense or maybe both. Try going into the advanced material settings and see if the either of those are on, i.e. any value that isn't zero. If they are, make Ambient and Transluscence color Black and the value Zero. Do that for each material of the hair. Try rendering again and see if this doesn't make that hair look better. In Poser 8 and above, using Ambience on a texture makes IDL consider it a source of light, and hair is not meant to be a light bulb.
Weapons of choice:
My suggestion is to turn off HSV Exponential in your render settings. Someone may suggest a better setting for it, but I never liked how it looked.
Weapons of choice:
According to the PoserSurface, you are routing both an Alt Specular and Specular_value thus multiplying that channel much higher than it needs. Use either one, not both. If you elect to use the node connected to the Alt_Specular, translate the values from the Specular_value to the node, zero the Specular_value and disconnect the map to it.
Quote - According to the PoserSurface, you are routing both an Alt Specular and Specular_value thus multiplying that channel much higher than it needs. Use either one, not both. If you elect to use the node connected to the Alt_Specular, translate the values from the Specular_value to the node, zero the Specular_value and disconnect the map to it.
Thank´s for the advice but that didn´t solve it, the hair still looks smudge when rendering with "Casts shadows" on. This problem occurs whenever I try to render a transmapped hair figure/ prop, with Casts shadows on.
Well...I solved the problem by increasing the "Raytrace Bounces". For some reason I once lowered it to 1, probably for saving time with some test renders...now i pulled it up to 4.
That made the trick:-)
Thank you all for the advices, it´s nice to see that you people still like to help!
You´re great!
Cheers/
Mike
I'm not 100% sure... but for scenes lit with IDL & GC shouldn't specular + diffuse strengths not exceed 1.... I was never clear on exactly how this worked but I remember something about it screwing up the light math if the values were too high.. effectively more light bouncing off the surface than what hits it. Maybe somebody with a keener understanding can explain what I'm getting at...
At any rate I notice your specular value is at 1.3 AND you have an alternate specular... could this be where the problem lies???
Also are you using a GC of 1 for your grayscale maps (Trans, Bump, displacement etc)
Quote - I'm not 100% sure... but for scenes lit with IDL & GC shouldn't specular + diffuse strengths not exceed 1.... I was never clear on exactly how this worked but I remember something about it screwing up the light math if the values were too high.. effectively more light bouncing off the surface than what hits it. Maybe somebody with a keener understanding can explain what I'm getting at...
There´s no Gamma Correction in Poser 8.
But thank´s anyway!
I'm sure I read somewhere that IDL needs a minimum of 2 raytrace bounces in order to 'see' transmapped objects correctly - and I see that you've fixed the issue by increasing bounces ...
Not approved by Scarfolk Council. For more information please reread. Or visit my local shop.
Quote - I'm sure I read somewhere that IDL needs a minimum of 2 raytrace bounces in order to 'see' transmapped objects correctly - and I see that you've fixed the issue by increasing bounces ...
that would make some sense.. one bounce being a direct light and the 2nd and subsequent bounces being the idirect light
Examples are with and without shadows on. The hair in this case is "Wild Hair".
I have Poser 8.
