Mon, Dec 23, 6:04 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 23 1:20 pm)
Subject: Poser Pro 2012 Crashing on Launch? Found Cause and fix
xocxoc ( ) posted Sat, 30 November 2013 at 11:41 AM · edited Fri, 22 November 2024 at 7:06 PM
I do not know if this is affecting other versions of Poser, but my Poser Pro 2012 recently stopped loading completely, giving the deaded "Poser Pro has crashed and needs to shut down" message before it even finishes opening.
After eliminating hardware causes and video driver causes, and problems with the program itself, I decided it had to be software compatibility.
Turns out it is Adobe Air which is used by Poser.
If you can't get Poser to launch completely anymore, uninstall it and uninstall Adobe Air.  Then reinstall, and reinstall the Service Release, and it should launch.  If at any point the program asks you to upgrade Adobe Air, DONT!!  Use the version that came with Poser, there is no need to upgrade unless you are a software developer.
willdial ( ) posted Sat, 30 November 2013 at 10:32 PM
Thanks for the FYI.
I found there is a way to tell Adoble AIR to not update itself. You have to download the Settings Manager. It is available at: http://airdownload.adobe.com/air/applications/SettingsManager/SettingsManager.air
xocxoc ( ) posted Sat, 30 November 2013 at 11:39 PM
Thanks, Adobe Air updates now disabled!
jorge.dorlando ( ) posted Mon, 02 December 2013 at 6:28 PM
Thank you!
I do not know that!
wrpspeed ( ) posted Tue, 03 December 2013 at 7:03 AM
thanks for the info. i think it was the new edition of internet explorer (11) that was causing it.
