Thu, Feb 20, 6:51 AM CST
Forum Moderators: RedPhantom
Subject: Just bought Vicky 4.2 with the Morphs how to use download manager to install to
DreamlandModels ( ) posted Sun, 08 December 2013 at 6:06 PM · edited Mon, 17 February 2025 at 7:13 PM
I just build products for Poser but only use it with the default characters. Wanted to use Danae's wonderful girls in my product images but have no idea what to do the get them into Poser 2012 Pro. Went and bought Vicky 4.2 and the Morph ++ products but the download manager takes them into Daz of which I have no idea how to use. Please help me with a step by step okay?
Tom
JimTS ( ) posted Sun, 08 December 2013 at 7:37 PM · edited Sun, 08 December 2013 at 7:38 PM
Do you know where your Poser 2012 Pro Content Directory is?
Make a folder in that directory called Victoria4 or whatever
Now manually download your V4.2 files
unzip the runtime folder files to your Victoria4 Folder
Run DzCreateExPFiles.exe in Runtime/libraries/!DAZ Folder
open poser and add Victoria runtime
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
 Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
WandW ( ) posted Sun, 08 December 2013 at 8:33 PM · edited Sun, 08 December 2013 at 8:35 PM
Just add the DAZ Studio content directory to your library as an external runtime.  I don't recall the default location offhand.
Alternatively, What I did was to create a folder as JimTS suggested, and added it as a DAZ Install Manager target folder; click on the gear at top right, and on the Installation Tab  at the bottom clicking on the+ sign will let you add a path.
You'll then need to uninstall what it installed to the DAZ Studio directory from the Installed Tab on the main window, go to the Ready to Install tab on and select your V4 directory as the path.  I've been told that you won't need to reinitailize after installing using this method, but I always do, as noted in JimTS's post.
BTW, if you are not using Studio much, uninstalling the DAZ Content Manager Service will save some memory, but won't affect DIM (at least for what I use it for, which is installing content for Poser)
DreamlandModels ( ) posted Sun, 08 December 2013 at 10:34 PM · edited Sun, 08 December 2013 at 10:35 PM
Thanks guys. I tried your way wand and the installer put everything in my Daz folders so I just pointed Poser to the content folder in Daz and seems like everything is there.
Time will tell.
Thanks to you both for the help. :-)
Tom
imagination304 ( ) posted Tue, 10 December 2013 at 3:44 AM
(bookmarked)
estherau ( ) posted Wed, 11 December 2013 at 5:24 PM
You can point your installer to put them wherever you like or just put them in an untitled folder then change the name of the folder and put it where you want.  but if you do this name change method then your uninstallers from the DLM will never work.  that doesn't matter to me. I can run them manually.
I keep all my content in lots of external runtimes so it gets to much to make all those shortcuts in the DAZ DLM.
Love esther
MY ONLINE COMIC IS NOW LIVE
DreamlandModels ( ) posted Thu, 12 December 2013 at 3:10 PM
Quote - You can point your installer to put them wherever you like or just put them in an untitled folder then change the name of the folder and put it where you want.  but if you do this name change method then your uninstallers from the DLM will never work.  that doesn't matter to me. I can run them manually.
Love esther
Hi Esther,
So please explain step by step how to install to a folder on my desktop with the installer from Daz called Download Manager, please?
I also have several runtimes on different hard drives that I point Poser to, just in case Poser goes funky on me.
Tom
RHaseltine ( ) posted Thu, 12 December 2013 at 3:40 PM
Click the gear icon at top-right of the Install Manager interface to open the Preferences Click the Installation tab. Click the + button at lower left. Name the folder so you can pick it later. Click the ... button on the right. Select your target folder in the browser. Click Accept to close the Add folder dialogue. Click Accept to close the preferences. Click Show Details in the Ready to Install tab, if you've already downloaded the files, or check Install after download and then Show Details in the Ready Download tab if not. Make sure that your chosen folder's description is listed. Download/install the files.
DreamlandModels ( ) posted Thu, 12 December 2013 at 3:46 PM
Thanks for laying it out straight for me.
Tom
estherau ( ) posted Fri, 13 December 2013 at 10:26 PM
yep - like that.
DreamlandModels ( ) posted Fri, 13 December 2013 at 11:27 PM
Worked perfectly! Thank you all for your help!
Tom
vilters ( ) posted Sat, 14 December 2013 at 7:37 AM · edited Sat, 14 December 2013 at 7:37 AM
All Vicky ladies live happily at :
Temple Square 1.
PP2014 Swordcity
Dazland
