Fri, Jan 31, 12:50 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 12:41 am)
Subject: Question on DSON Importer
gohanf22 ( ) posted Sat, 28 December 2013 at 1:42 PM · edited Fri, 31 January 2025 at 12:49 AM
Does anyone know if they will be making a new one for Poser 10 and Poser Pro 2014 or they not going to? Or is there a workaround with the current DSON?
WandW ( ) posted Sat, 28 December 2013 at 1:46 PM
DSON Importer works fine for me in Poser Pro 2014.  Did you download the current version from DAZ and install the Starter Essentials and its Poser Companion files?
gohanf22 ( ) posted Sat, 28 December 2013 at 1:50 PM
Well when I tried to install it or when I did install it, it gives me an error at program startup that says: An error occurred while importing addon DSON: ERROR: DLL load failed: %1 is not a valid Win32 application.
Any idea how to fix it?
hborre ( ) posted Sat, 28 December 2013 at 2:40 PM
Are you sure you are using the right version?  There is a 32-bit and 64-bit version.
gohanf22 ( ) posted Sun, 29 December 2013 at 6:10 PM
Last I checked I was using 64 bit Windows. And I downloaded the right one to install so I have no idea why its doing this.
WandW ( ) posted Sun, 29 December 2013 at 6:26 PM · edited Sun, 29 December 2013 at 6:26 PM
Are you running Poser 10 or PP2014?  You need the 32-bit one for Poser 10.  If you are using PP2014, make sure you are actually running the 64-bit version of Poser; it installs both 32 and 64-bit by default....
gohanf22 ( ) posted Mon, 30 December 2013 at 12:25 PM
I'm using Poser 10 and I got it sort of working now. I installed the 32 bit version. It still giving me an error but the models are loading. Thanks everyone for the help
drifterlee ( ) posted Tue, 31 December 2013 at 6:59 PM
I am using Poser Pro 2014 and the latest download of DSON Importer. I bought the Mil Cat 2 and it will not load at all.
WandW ( ) posted Tue, 31 December 2013 at 9:04 PM
Did you install both the DSON Core and Poser CF files for the kitty?
PS. Happy New Year!  😄
drifterlee ( ) posted Wed, 01 January 2014 at 7:43 AM
Yes, I did.
WandW ( ) posted Wed, 01 January 2014 at 8:27 AM
Did you install Genesis 2 Starter essentials?  I don't have the Cat, so I'm just tossing out ideas at this point...
drifterlee ( ) posted Wed, 01 January 2014 at 8:38 AM
Would the Genesis 2 starter essentials apply to the Big Cat? I have Genesis installed so I must have installed it.
RHaseltine ( ) posted Wed, 01 January 2014 at 8:51 AM
Do you get an error message? Is the cat listed as loaded but simply not visible, or isn't there even a ghost listing? Are you sure you are loading the figure and not materials etc.?
WandW ( ) posted Wed, 01 January 2014 at 9:00 AM
I believe it's based on Genesis 2.  The Gen. 2 Starter Essentials downloads (DSON Core and Poser CF)  will be in your DAZ account's Product Library and/or DIM. As I said, I don't have it, so I'm just tossing out ideas...
RHaseltine ( ) posted Wed, 01 January 2014 at 9:09 AM
The Big Cat 2 is a stand-alone figure, with its own mesh and rigging.
drifterlee ( ) posted Wed, 01 January 2014 at 9:45 AM
I try to load the cat and it is like the ghost of a cat and the program immediately freezes. That's wht happens. Do you have the Big Cat 2? for Poser
RHaseltine ( ) posted Wed, 01 January 2014 at 2:51 PM
I do, but I still need to download the latest SRs for Poser, so I can't test yet.
