Mon, Jan 20, 6:56 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 6:43 am)
Subject: What did I do to screw this up...
Winterclaw ( ) posted Sun, 29 December 2013 at 11:07 AM · edited Sun, 05 January 2025 at 1:05 AM
Okay, I had a save file of vicky in a pose that I had as a start to a render.  I hit render to test it out.  The SSS renders fine, but when the final render comes, all I see is the background, no vicky.  I turn SSS off and still no vicky.  When I saved the file when I first worked on it, I didn't have this problem.
Yes all the visible boxes are checked.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
hborre ( ) posted Sun, 29 December 2013 at 11:30 AM
Online Now!
Do you have raytrace lighting or depthmap?
Winterclaw ( ) posted Sun, 29 December 2013 at 3:14 PM
Raytrace
WARK!
markschum ( ) posted Sun, 29 December 2013 at 5:47 PM
so...
visible in preview
rendering the correct camera
visibility on for both
nothing in front of the camera (or behind the camera)
what if you add a prop near Vicky , does it render ?
Winterclaw ( ) posted Sun, 29 December 2013 at 5:56 PM
Thanks for the replies, I figured it out.  I needed to turn the default ground prop that loads up with every scene off because of the angle I was using.  Because it is a similar color to the default background, that led me off.
WARK!
