Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 6:43 am)
Raytrace
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Thanks for the replies, I figured it out. I needed to turn the default ground prop that loads up with every scene off because of the angle I was using. Because it is a similar color to the default background, that led me off.
WARK!
Okay, I had a save file of vicky in a pose that I had as a start to a render. I hit render to test it out. The SSS renders fine, but when the final render comes, all I see is the background, no vicky. I turn SSS off and still no vicky. When I saved the file when I first worked on it, I didn't have this problem.
Yes all the visible boxes are checked.
WARK!
