Don't worry about the darkended texture in the hip area - this happens by default if you load the original M4 in Poser (looks normal in DAZ Studio). If you use other MATs this will not happen. And if you use EZ's EZSkin2 it will vanish anyway.
Concerning your "Eryk" morph: did you install the 'Base M4' morphs and the 'Morphs ++ M4'? They are needed for other "commercial character morph packages" as "Eryk".
Since V4 works fine you will be able to install M4 too.
I have all the m4 morph packs, and used the DAZ Install Manager to put them into my runtimes. However, after fooling around I did figure out that the elite morphs are what was not working correctly. So you were spot on Mack.
Luckily my hard drive had an old download of the morphs from 2 years ago and I reinstalled them manually. They work fine now and fixed the problem. Apparently the daz installer does not put the elite morphs in the correct place or the files are messed up. All of the rest of the content installed fine using the DAZ Install Manager so go figure.
Nope I didn't, I hadn't had to run a file on anything else and didn't for morphs ++ and it works fine. Guess I missed where it instructed me to run that on M4 elite. I did run DZCreateEXPFiles-m4.bat because I thought that updated things but I guess I really didn't understand the installation process.
Running the bat file is required every time a different morph package is installed. So perform the following sequence: install Morph++, run bat file, install Elite, run bat file, etc. Just keep in mind, this procedure will only update your base model, not any previous model already saved back into your library prior to the package installations.
Well if DZCreateEXPFiles-m4.bat is what I was supposed to run to update the elite morphs I had done that. It was one of the things I did when I couldn't get the morphs to work right although now I will run it whenever I install anything for M4. So I still don't get why the elite morphs didn't install correctly using the DAZ Install Manager, but it works now so I am happy. Thanks for all the replies and help.
When I load michael he has a darker gray area on his groin area. When morphs packages are injected they just don't seem to "take" in that area. Materials work fine in that area but the morphs are messed up. I have a clean install of poser pro 2014 with service pack 3. I have also uninstalled M4 and all his morphs I purchased from DAZ studio and reinstalled them completely. Nothing seems to help.
The attached image is an example JPG of michael 4 with and without the Eryk body moph applied. I think the issue is clear in the image but if not I can supply other images. Any help would be greatly appreciated as I am tearing out my hair over this.
