Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Attached Link: Animation Tutorial
*(click on the image to view full size)* *(click the Attached Link above the image to view the complete FREE tutorial)*Try using the Graph window to see what is happening.
Note - This tutorial was done for Poser 4 but the Graph window functions are basically the same for Poser 6.
Cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
I wanted to show off a sword I made by animating it in poser. I started the first frame with it in the case and then went to about frame 30 and made a keyframe. I changed the y translation to pull the sword up out of the case. Then I went and made a keyframe at about 60 and moved the sword forward and down.
What I got however was the sword moving down between the first 15 frames and then bobbing back up to where it should be by frame 30. What happened?
