Sun, Feb 16, 5:26 PM CST
Subject: Hey could some post an image of their Daz3d content folder tree that their Poser
rowlando ( ) posted Tue, 07 January 2014 at 7:49 PM · edited Sun, 16 February 2025 at 5:22 PM
I think an image showing what folders are contained and how they relate would be very helpful.
My file structure to access Daz3d Content ie Genisis is a mess, any help via images would be most beneficial please
Cheers Rowlando
Seek what you can never loose
mjmdvm ( ) posted Wed, 08 January 2014 at 7:47 AM
Here's my set up. First, my main Poser Pro 2014 installation is located outside the Programs directory ( Windows 8) in a folder called C:Poser Pro 2014. This avoids problems with Windows' annoying UAC.  I also do not install any content into that main Poser directory. Everything goes into external runtimes that live in a folder on my desktop ( backed up onto external hard drives). I basically copied the file structure from the downloads section of the main Poser install.  Poser tends to run faster if that main directory is as clean as possible, especially if running DSON( at least for me anyway).
DSON content goes into that same folder on my desktop in a DAZ Studio type file structure ( see attachment). I had DAZ Studio 4.6 installed at one time and just copied the file structure.  But you don't need DAZ Studio installed to run DSON. It will install a DAZ Studio type folder when you go through the DSON install process if I remember correctly.
Once the DS folder was on my PC,  I moved it from the default location unde My Documents just to make it easier for me to find stuff if I need to do any direct manipulation of files. This is the folder that gets linked to Poser to make DSON content work.  It's also where I point the DAZ Install Manager to.
Older Poser specific DAZ content that uses the old installers get installed into the default Poser Directory and then moved into one of my other runtimes.   Content delivered in ZIP files get unzipped to the desktop and then are copied  into the desired target runtime.
Hope this helps.
Here's where my main Poser lives
rowlando ( ) posted Wed, 08 January 2014 at 7:34 PM
Hey Thanks mjmdvm
I am using windows 7
My problem was having a folder called Content that Poser Pro uses and another folder called Studio that Daz4.5 uses.
I could not get poser to read the studio folder.
I am trying to merge these folders so that I only have a Content folder containing all files for both PP and Daz 4.5
I have done my best so far in that I the following tree of folders could you check out the image and let me know if you see something wrong.
Cheers Rowlando
mjmdvm ( ) posted Thu, 09 January 2014 at 9:07 AM
You're welcome.  Windows 7 is pretty much the same as 8 except for that silly Metro thingy- at least from what I can tell.  So basic folder setups should be the same.
At first look it seems like the DAZ Studio folder structure has somehow been merged into Poser's main content location.  As you can see from an expanded view of my DAZ Studio type directory, I do not have a DSON folder, nor do I have an Instaqll Manager directory anywhere . Also my runtime folder inside the DAZ Studio looks very different.
For the DSON thing to work there has to be a DAZ Studio directory living independently outside of Poser. Your DSON installer does go into the main Poser directory. But the actual Poser companion files go into that DAZ Studio directory.  To see and use the content in Poser, the DAZ Studio directory is added to Poser as an external runtime. I'll post some more pics to see if they help.
mjmdvm ( ) posted Thu, 09 January 2014 at 9:10 AM
Here's an expanded view of my main Poser Pro 2012 runtime to illustrate where your DSON folder should be
mjmdvm ( ) posted Thu, 09 January 2014 at 9:23 AM
Just as a reference, this image shows how I added my DAZ Studio type directory to Poser.
mjmdvm ( ) posted Thu, 09 January 2014 at 9:31 AM · edited Thu, 09 January 2014 at 9:37 AM
Here's how I set up the DAZ Install Manager to find where I put my DAZ Studio directory.  Remember, it's Ok to leave things at their default locations too. I just came up with this way of doing things after many hours of reading posts here and many more hours of trial and error.
mjmdvm ( ) posted Thu, 09 January 2014 at 9:35 AM · edited Thu, 09 January 2014 at 9:36 AM
One last tip.. I found it easier to navigate the DIM if I made sure to set the download filters to include only those files needed to make DSON content work in Poser. othjerwise I see all the DS specific stuff too and it gets too confusing.
rowlando ( ) posted Fri, 10 January 2014 at 2:09 AM
Hey thanks for all the images, I think I have found the problem, see attached image.
I merged everything into one file called Daz3D/Content and left the DSON folder under runtimes.
I merged everything so I did not have duplicate files everywhere and the sturcture was not working anyhow.
I can see from my folder tree that I have Gen1 outside of the runtimes, and gen 2 inside the runtime under DSON folder.
Poser can open Gen2 so I figure I could move Gen1 with it and poser should open it, maybe what do you think. Cheers
rowlando ( ) posted Fri, 10 January 2014 at 2:47 AM
Hey could you show me the data file that is outside of your runtime, this contains all the files for genisis 1 and 2.
I can then compare my genisis data files to see if I am missing something.
Thanks Rowlando
mjmdvm ( ) posted Fri, 10 January 2014 at 7:33 AM · edited Fri, 10 January 2014 at 7:34 AM
Looking a bit better, but there shouldn't be a props folder where Genesis base lives.  I just have Genesis 2 installed right now, but the locations are the same. Here's what mine looks like.
mjmdvm ( ) posted Fri, 10 January 2014 at 7:45 AM
It looks like Props live in one of two locations from what I can tell.  I did a quick install of a DSON compatible prop set with the DAZ Install Manager to show you where it went.
mjmdvm ( ) posted Fri, 10 January 2014 at 7:59 AM
This is my Data file that contains all of the DSON compatible content. It lives in a folder on my desktop.
I was confused about this stuff for a long time too.  Being a long time Poser user ( since version 2) I knew exactly where things were supposed to go. The DAZ Studio set up is completely different, so it took many tries before I could understand where things went.  I probably have some folders in my directory that don't need to be there for DSON to work with Poser.  But I leave the basic set up alone .  It took me too long to figure out how to get this far :-)
rowlando ( ) posted Sat, 11 January 2014 at 3:00 AM
I am cleaning up the folder structures, thanks so much for the images, will post back onece I get things going again.
Cheers Rowlando
mjmdvm ( ) posted Sat, 11 January 2014 at 9:02 AM
You're welcome Rowlando!
rowlando ( ) posted Tue, 21 January 2014 at 5:05 PM
Hey just thought I would let you know, I have found multipull instances of a Daz folder in my documents folder and now one in my C:/ PoserPro folder.
Poser loads the Gen1 from its C:/drive and loads Gen2 from my documents folder.
Its become a real mess to navigate so I am having to search and modify what I find.
What a mess, thanks for the help.
Rowlando
mjmdvm ( ) posted Wed, 22 January 2014 at 9:08 AM
Funny you should say that.. I'm now seeing multiple instances of my DSON content folder inside Poser ( 2 yesterday, 3 this AM). Yet there's only ONE copy on the desktop. It's like Poser has decided to copy things internally and that is slowing the program down a LOT.
Darn computers! :-P
rowlando ( ) posted Wed, 22 January 2014 at 11:38 PM
I am just having to go through it all to make I know where things are, as long as the program works I am happy.
Daz3d seems to work and find things OK and so Dose Poser now, I thought I could have everything for both programs in my documents folder other than what is needed inside of poser.
Cheers Rowlando
