Dawn is only compatable with Poser 9+
Debut offers none of the features to make Dawn, Dson or any of that stuff work. Here's a link to the feature comparison:
http://poser.smithmicro.com/poser10-poserpro2014/?__utma=267329180.1623127561.1321329542.1388871174.1389289664.168&__utmb=267329180.4.10.1389289664&__utmc=267329180&__utmx=-&__utmz=267329180.1387816940.159.13.utmcsr=poser.smithmicro.com|utmccn=%28referral%29|utmcmd=referral|utmcct=/content_update.html&__utmv=-&__utmk=208190609#compare
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
Quote - Dawn is only compatable with Poser 9+
I understand all that, and I am going to upgrade, but my question was where does one get DSON? Is it part of later versions of Poser? Is it part of DAZ3D? Can I download it from the DAZ3D or SmithMicor website?
Thanks...
Knickers
Quote - And there are 2 versions of Dawn, one for Poser and the other for DS. As JimTS posted, Dawn is totally incompatible with Poser Debut. You are expecting too much from an application which only provides very basic and limited tools.
Installing Debut was me testing my abilities to run it, gaining some experience running it, and whether Poser looked like it would do what I want it to do, before laying down much more hard earned money for a better version (Debut cost me $12). As far as I'm concerned, Debut is only a learning tool, nothing more. Installing Dawn (I even managed to install the Mac version) was also just a test, I knew when I installed it that it was designed for 9+, but I'll hang on to Dawn's Runtime (I installed it in a separate Runtime, as you suggested a few days ago) and use it with Poser ∞.
Everything is under control...
Knickers
1 See my previous statement
2 Posable well no, boned but not really rigged
3 Dson is a DAZ3D product so guess where you'll get support for it
Charles Péguy
OK, when I tested dawn in Poser Debut, I only loaded her to see if she'd load, I didn't try posing her. Sorry for the misinformation. (I got Poser debut free from Smith-Micro and although I already had Poser 9 at the time, I tried it out a little, but didn't try to do any serious work with it).
But, yeah, if you can get Poser 9 or 10, by all means do so, it's an enormous improvement over Debut. People on eBay are selling brand new copies of P9 for as little as $50, and Amazon has Poser 10 for only $82.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
Quote - > Quote - To answer the original question: DSON is available at the Daz3d website. It is a stand alone product and does not require DazStudio to be installed.
That's what I wanted to know, do you know if ii's a freebee?
Thanks...
Knickers
I think I found it, listed as the DSON editor?
Knickers
Type "DSON" in the search window iof the Daz homepage.
The "DSON Importer" is the one you want. And yes. It is free.
To reiterate what has been said above: It DOES NOT work with Poser Debut. It was not designed to work with it.
And with that, I'm at the end of my ability to help. It doesn't work for me. There are several here who have had success with it, and I'm sure they will help with specific questions you may have about getting it correctly installed and working.
Quote - Type "DSON" in the search window iof the Daz homepage.
Yes! I found it, downloading it now.
Thanks!
Knickers
Quote - Why would you need DSON for Dawn she is not a DAZ product
or are you referencing a Genesis character
I was also playing around with other characters. It was with the Basic Female included with Victoria 4 (I believe). I'm in a learning mode so I'm just trying all sorts of things.
This is the message I was getting:
Traceback (most recent call last):
File "/Users/Shared/My DAZ 3D Library/Runtime/libraries/Character/DAZ People/Basic Female.py", line 1, in ?
import dson.dzdsonimporter
ImportError: No module named dson.dzdsonimporter
I am going to get Poser 10 so it probably will take care of itself, when I do that.
Knickers
Quote - > Quote - Why would you need DSON for Dawn she is not a DAZ product
Knickers
I'm finding 'anything' that uses Genesis 2 generates that error message...
Knickers
Quote - > Quote - > Quote - Why would you need DSON for Dawn she is not a DAZ product
Knickers
Knickers
You're getting that error message because you're using a version of Poser that does not support the importer calls that Poser has plugin support for or the wrong version (when you install the 64 bit version in Poser 9 or 10, which does not support 64bit).
I'm a new Poser (Debut) user and I have tried to install Dawn. I know I'm not compatible, since Debut is Poser 8 and Dawn requires Poser 9+, but it does run and will insert a base Dawn into a scene. Some of the operations I try on Dawn I get an error message that says DSON is missing (or unable to find it... something like that), is DSON necessary for using Dawn in Poser and if so, where can I find it?
Thanks...
Knickers
