Sun, Feb 9, 12:04 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 11:05 am)
Subject: Specular in hair ... need a little help here.
Boni ( ) posted Wed, 22 January 2014 at 4:38 PM · edited Sun, 09 February 2025 at 12:04 PM
Attached Link: Shroedinger's Package
I had a happy accident with an image I did (see attached) and am working on a similarly lit scene.  I want to use another hair piece for the new image but I'm not sure which hair models will do this.  I have most of the older hair models from DAZ, some from here ... and wonder if anyone else has tried making realistic specular  effects on hair for high intensity lighting.  What hair works better.  I know, I just want to save hours and hours of render time testing hair.  I can be soooo lazy. ;).
Thanks for the help guys.
Boni
Boni
hborre ( ) posted Wed, 22 January 2014 at 6:14 PM
Why don't you just copy the shader arrangement from the hair that worked well for you to the other hair model?  Use the same node values as before.
grichter ( ) posted Wed, 22 January 2014 at 9:58 PM
I do what hborre suggests all the time. Copy a shader into some other item and disconnect the maps of the copied from and reconnect the maps of the copied too and then used the macro on the right side of the materail room to delete detached nodes to clean things up.
What you have to watch out for in hairs especailly older ones is the specular could have been baked into the texture to start with and the results of the above method will not look the same.
Gary
EnglishBob ( ) posted Thu, 23 January 2014 at 4:37 AM
The trouble is, part of the beauty of a happy accident is that it takes no effort... :) I doubt the same will be true when you try to replicate it.
As grichter says, highlights which are 'baked' into the hair texture can be a hindrance. Sometimes they work for you, sometimes they don't. There was some discussion around this subject, but I don't recall any real conclusion being reached.
I sometimes remove the texture map from transmapped hair, and leave just the transparency and a solid colour. This looks muddy by itself, as if the hair hasn't been washed recently, but you may have some luck adding your own specular effects back into that mix.
vilters ( ) posted Thu, 23 January 2014 at 5:33 AM
Now,
connect the hair diffuse map into displacement and set displacement to 0.1 for extra realistic results.
Boni ( ) posted Thu, 23 January 2014 at 9:33 AM
Wow, some great suggestions.  Thank you very much.  I will try these and let you know the results.
Boni
Boni ( ) posted Thu, 23 January 2014 at 3:25 PM
Okay here is the finished piece.  What do you all think?
Boni
Boni
EnglishBob ( ) posted Fri, 24 January 2014 at 4:07 AM
I think I'm not getting ebots for this thread. That's what I think. :-)
But to answer your question... The hair highlights haven't worked nearly as well on this one as they did on your original "happy accident". Here, they look metallic and generally false. Whatever you did on Schoadinger's Package hasn't happened here, unfortunately.
Is it the same hair? You could just save a material collection from the Schoadinger's Package hair and apply it to the new scene. There may be something going on with the lighting or render settings, but that should help at least.
(I know we're talking about the hair, but those chairs look as if they could do with smoothing turning on - and of course there's pokethrough on her clothes, which I dare say is on your 'to-do' list already!)
Quote - Now, connect the hair diffuse map into displacement and set displacement to 0.1 for extra realistic results.
0.1 what? Not metres, hopefully? :P
hborre ( ) posted Fri, 24 January 2014 at 8:24 AM
If we are referring to the female hair, the specular value looks complete blown; too much specularity.  The other issue, as grichter posted, is baked-in specular highlights into the image map which is much more difficult to control.  Englishbob's map substitution solution is feasible, granted that the images are close to the same in detail, composition and resolution.  Without seeing the actual hair texture map, it will be difficult to suggest a solution.
Anthanasius ( ) posted Fri, 24 January 2014 at 11:41 AM
Hi !
The shader i use, from BagginsBill
Génération mobiles Le Forum / Le Site
Miss Nancy ( ) posted Fri, 24 January 2014 at 1:09 PM · edited Fri, 24 January 2014 at 1:19 PM
bill's shader looks good IMVHO.  am hoping somebody will create standard fresnel node set-up for hair, e.g. diffuse node blended with colour math node into which goes reflection and blinn (or other specular).  he posted this shader in other thread, but it may not yet be ready for use with hair (no way to plug in texmap yet).
p.s. très jolie votre avatar!
Anthanasius ( ) posted Fri, 24 January 2014 at 6:21 PM
Other BB Shader
Anthanasius ( ) posted Fri, 24 January 2014 at 6:23 PM
And one more
@Nancy, thx, it's me on the avatar ;)
Miss Nancy ( ) posted Mon, 27 January 2014 at 12:21 PM
those also look good.  did he do one with scatter?  if you backlight somebody's head, you can see the scattering, and black hair tends to scatter everything but blue with global illumination.  hair also reflects the scene around it, depending on how clean and smooth it is.
Anthanasius ( ) posted Tue, 28 January 2014 at 10:57 AM
Hum ... Poser isn't so beefy to use sss and reflection at the same time on hair :lol:
toastie ( ) posted Mon, 03 February 2014 at 7:04 AM
Can someone tell me where to find BagginsBill's hair shaders please? Looked on his Google site and can't see them anywhere.
hborre ( ) posted Mon, 03 February 2014 at 9:11 AM
This may be the link for the BB hair shader.
https://sites.google.com/site/bagginsbill/free-stuff/random-shaders
There was also a VSS prop for hair which I couldn't find straight off.
hborre ( ) posted Mon, 03 February 2014 at 9:13 AM
https://sites.google.com/site/bagginsbill/file-cabinet
Hair Prop VSS
toastie ( ) posted Mon, 03 February 2014 at 9:23 AM
Thanks!
Is it the file VSSM4HairBooster.zip then? There didn't seem to be anything else to do with hair and I was looking for the ones that were shown earlier in the thread.
hborre ( ) posted Mon, 03 February 2014 at 9:28 AM
Those are the only 2 I am familiar with on his site.  I do believe that the M4 hair booster is his latest.
toastie ( ) posted Mon, 03 February 2014 at 9:31 AM
Ok. Thanks.
There were three that Anthanasius posted above that looked really good so those were the ones I was trying to find. I s'pose I could just copy the settings instead.
hborre ( ) posted Mon, 03 February 2014 at 9:48 AM
I can verify that the first Anthanasius image post is from the VSS Prop.
toastie ( ) posted Mon, 03 February 2014 at 9:58 AM
So I need to download the VSS prop as well? Ah, Ok. I thought the shaders were something separate so that's why I was having trouble finding them before.
Thanks again.
hborre ( ) posted Mon, 03 February 2014 at 12:36 PM
If anyone is using Snarly's EZSkin, you can use the hair settings for transmapped pieces.  I would say that results are rather good.  You can also add SSS to the shaders but render time will increase.  The image is a render in PP2014 using EZSkin applied to the hair without SSS.  Specular highlights were reduced to 10% (Default = 60%), 1 infinite light and BB's envsphere; IDL render.  Morph brush and render sub-division was applied to smooth out the sharp bends in the mesh.
piersyf ( ) posted Fri, 28 February 2014 at 7:02 PM
I've been playing with EZSkin quite a bit lately and have found that I get nice results with transmapped hair and IDL if a few things are in place;
  1. very subtle baked specularity, or even better, none.
  2. run snarly's scene fixer to fix the trans maps. Improves hair density
Miss Nancy ( ) posted Mon, 03 March 2014 at 12:00 PM
kozaburo-sama found same thing: bake in specular of poser hair, going back to P4. poser can simulate specular on hair with direct or indirect lite, but I'm not seeing any fresnel shaders for hair yet.  bill added schlick approx. in first shader posted above by anthan, and that's about it.
not certain about this, but some of 'em may still be turning off raytracing for hair, to speed it up.
shedofjoy ( ) posted Wed, 05 March 2014 at 6:52 PM
Attached Link: Hair shader
A link into my old hair shader. which sadly i no longer use as i render in reality 3. although i still have my more advanced versions stored somewhere in my runtime.
Getting old and still making "art" without soiling myself, now that's success.
WandW ( ) posted Wed, 05 March 2014 at 10:03 PM · edited Wed, 05 March 2014 at 10:04 PM
Quote - A link into my old hair shader. which sadly i no longer use as i render in reality 3. although i still have my more advanced versions stored somewhere in my runtime.
That looks really good.  However, I couldn't find the actual shader anywhere in the thread...
