Fri, Nov 22, 10:54 PM CST
Subject: I do material but not
atpo ( ) posted Tue, 04 February 2014 at 11:23 PM · edited Fri, 22 November 2024 at 7:25 PM
I try do material like pic
but not
skin material is not
nipple is not
what bump of nipple and skin is ?
that bump is diffult
I creat a plane, then adv materail ,then bump add "clouds"
but not the same with pic
hborre ( ) posted Wed, 05 February 2014 at 7:02 AM · edited Wed, 05 February 2014 at 7:02 AM
You must use the nudity warning when posting those type of images.
geep ( ) posted Wed, 05 February 2014 at 8:35 AM
Ok then, I'll check the "N" flag. 😄
cheers,
dr geep ... :o]
edited 10/5/2019
Steeleyes101 ( ) posted Wed, 05 February 2014 at 9:33 AM
Love the water effect how did you do that??
WandW ( ) posted Wed, 05 February 2014 at 9:41 AM
V4 base doesn't include a nipple morph.  It is included in the Morphs++ package.
Here is a free nipple morph for V4...
http://www.sharecg.com/v/23884/browse/11/Poser/Victoria-4.2-nipples-morph
Steeleyes101 ( ) posted Wed, 05 February 2014 at 9:55 AM
Thanks much for this
WandW ( ) posted Wed, 05 February 2014 at 10:06 AM
Also, if you want to make the skin appear wet, it can be done with EZSkin if you are using Poser 9 or higher.  It is a free download; make sure you get the files in the first post and the update in the last post here...
http://www.snarlygribbly.org/3d/forum/viewtopic.php?f=27&t=134
Wet skin will be in the FX tab after you set it up...
rokket ( ) posted Wed, 05 February 2014 at 5:26 PM
Quote - Love the water effect how did you do that??
That's not a render. It's a refernce pic the OP was trying to emulate.
Miss Nancy ( ) posted Wed, 05 February 2014 at 5:44 PM · edited Wed, 05 February 2014 at 5:45 PM
thx fr lnx, W.
