Quote - So I just figured out hex tiling. It's not perfect yet - the edge width of the tiles is not uniform - the horizontal side has lower slope than the others.
How on earth did you manage that??
S'ok - just a rhetorical question - it should probably remain a closely guarded secret :-)
I racked my brains for ages trying to think of a way to do that, unsuccessfully. Well done!
Free stuff @ https://poser.cobrablade.net/
This was an excellent brain teaser. Now - the next puzzle is how to allow the tiles to be different colors.
This is with no grout depth.
Going to bed now.
That looks like the chrustmas ornaments that are made out glass but have a metalic finish inside so the look like they are made of metal.
Well, I've done about all I can on this: I acknowlege that I'm no tailor. Trying to compensate for M4's default bowling ball shoulders is HARD!
Anyway, here's the final look: Each piece (except for the buttons) will have it's own named material zone for easy tweaking, but the UV map will be laid out as shown, so that a single pinstripe texture should lay on the coat properly.
If this looks alright, I'll get it packaged up and sent to you at your convenience.
I'll get the .obj file prepped and uploaded by Saturday. (Real-life intrusions, ya'know! grin)
You can run these straight into a Blender blending factor and generate any two colors.
Here is Loom_Contrast
Quote - Loom_GlennPlaid
That lefttop houndstooth is mighty impressive.
Here's a closeup of squircle + diamond.
But what if you go past 1? Fascinating. At 2 you get a diamond. (Which is still a square, but rotated 45 degrees.)
And at 3, a new shape which is called an astroid. It is a diamond with circles cut out of its sides. Of course you can dial in any in-between values you want.
Past 3 it just becomes a narrower astroid - a diamond with squircles cut out of it.
Left to right, squircle + circle, astroid + circle, astroid + astroid.
Attached Link: Cathedral Windows quilts
> Quote - The formula for a squircle has an exponent in it. When this value is 0 you get a square. When it is 1, a circle. In between 0 and 1, you get the squircle shapes I've been showing. > > But what if you go past 1? Fascinating. At 2 you get a diamond. (Which is still a square, but rotated 45 degrees.) > > And at 3, a new shape which is called an astroid. It is a diamond with circles cut out of its sides. Of course you can dial in any in-between values you want. > > Past 3 it just becomes a narrower astroid - a diamond with squircles cut out of it. > > Left to right, squircle + circle, astroid + circle, astroid + astroid.The example on the right looks like a quilting pattern called Cathedral Windows..
From previous posts...
The center one is rotate 45
Center one here also is rotated 45
Center one here is rotated 30
First one here is rotated 45
I'm making it into an EZMat plugin.
