Fri, Jan 24, 4:19 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Any idea how enable Animation Toggle option via script ?
  • 1
  • 2
andygraph ( ) posted Mon, 10 February 2014 at 2:45 AM · edited Tue, 21 January 2025 at 7:11 PM
Any idea ?
timarender ( ) posted Mon, 10 February 2014 at 2:51 PM
Is that the purpose of the method "SetAnimated"?
andygraph ( ) posted Mon, 10 February 2014 at 3:41 PM
I have a script but dont know where insert SetAnimated, if its work ...
andygraph ( ) posted Mon, 10 February 2014 at 3:53 PM
this script is for import obj sequence and hide/show frame by frame
its work for import obj, fine but the objs are all hide and don't have show enable on frame:
file_001.obj     show in frame 1
file_002.obj     show in frame 2
i believe its because the animaion toggle is not enable in script
markschum ( ) posted Mon, 10 February 2014 at 6:56 PM
try changing the lines that use SetOnOff  to SetVisibleInRender
this parameter does not need to be activated for animations.
andygraph ( ) posted Tue, 11 February 2014 at 2:47 AM · edited Tue, 11 February 2014 at 2:54 AM
try it, change nothing :-(
obj series importer
import poser, os
scn = poser.Scene()
fig = scn.CurrentFigure()
sdir = "C:UsersAndryDesktopTEST"
frame = 0
myfiles = os.listdir(sdir)
print myfiles
for myfile in myfiles:
if myfile[-3:] == "obj":
cfile = os.path.join(sdir, myfile)
try:
print cfile
imex = scn.ImExporter()
options = imex.ImportOptions("obj", None)
options[poser.kImOptCodeMAKEPOLYNORMSCONSISTENT] = 0
options[poser.kImOptCodeOFFSETZ] = 0.0
options[poser.kImOptCodeOFFSETY] = 0.0
options[poser.kImOptCodeOFFSETX] = 0.0
options[poser.kImOptCodeFLIPUTEXTCOORDS] = 0
options[poser.kImOptCodeWELDIDENTICALVERTS] = 0
options[poser.kImOptCodeCENTERED] = 0
options[poser.kImOptCodePERCENTFIGSIZE] = 0
options[poser.kImOptCodeFLIPVTEXTCOORDS] = 0
options[poser.kImOptCodeFLIPNORMS] = 0
options[poser.kImOptCodePLACEONFLOOR] = 0
imex.Import('obj', 'File Format Wavefront', cfile, options)
act = scn.CurrentActor()
act.SetName(myfile[:-4])
act.SetVisibleInRender(1)
frame = frame + 1
scn.SetFrame(frame)
act.SetVisibleInRender(0)
if frame > 2:
scn.SetFrame(frame - 2)
scn.SetFrame(frame)
except:
print "t error on ",myfile
print "Done"
andygraph ( ) posted Tue, 11 February 2014 at 4:21 AM
If a check the animation toggle it show the visible dial ..
so i believe if is possible add a visible dial to prop via script is possible animate it.
andygraph ( ) posted Thu, 13 February 2014 at 5:03 AM
no solution ?
pleeeeease :-(
structure ( ) posted Sat, 29 March 2014 at 10:55 AM
Forum Coordinator
SetAnimated is listed under Shader Node Input methods.
I think you would be better writing a toggle function. I am not entirely sure what exactly you are after, but maybe something like this would work
import poser
scene=poser.Scene()
def toggleanim(scene,framecount,toggle=False):
    scene.SetFrame(0)
    if toggle:
        for frame in range(frames):
            scene.SetFrame(frame)
    else:
        return False
toggleanim(scene, framecount, True)
the third value ( True ) should overwrite the default of False and therefore the animation should toggle (in this case frame by frame)
Locked Out
andygraph ( ) posted Sun, 30 March 2014 at 7:54 AM
How i can add this script in obj loader sequence script ?
structure ( ) posted Sun, 30 March 2014 at 8:20 AM · edited Sun, 30 March 2014 at 8:28 AM
Forum Coordinator
after looking at your code it seems you want to make an actor invisible in certain frames and visible in others so there are 3 ways to accomplish this :
as markschum said you can use
setvisibleinrender
or you can use
SetVisible
SetVisibleInCamera
import poser
scn=poser.Scene()
def ActVisible(act,toggle,frame):
    act.SetVisible(act,toggle,frame)
ActVisible(act,1,0)
frame = frame + 1
scn.SetFrame(frame)
ActVisible(act,1,frame)
if frame > 2:
    ActVisible(act,0,frame)
scn.SetFrame(frame)
both setvisibleinrender and setvisibleincamera will not appear to do anything until you actually render
Locked Out
andygraph ( ) posted Sun, 30 March 2014 at 8:31 AM · edited Sun, 30 March 2014 at 8:42 AM
i have wrote:
obj series importer
import poser, os
scn = poser.Scene()
sdir = "C:Users"
frame = 0
print myfiles
try:
print cfile
ActVisible(act,1,0)
frame = frame + 1
scn.SetFrame(frame)
if frame > 2:
scn.SetFrame(frame)
except:
print "Done"
but i found error message if run this script:
line 33
IndentationError: unexpected unindent
important i dont want invisible in render only but i need invisible obj in scene:
because I have to load heavy objects and this is the only way to lighten the scene
structure ( ) posted Sun, 30 March 2014 at 8:35 AM · edited Sun, 30 March 2014 at 8:44 AM
Forum Coordinator
i can't tell where your indentations are but it seems to me that line 33 should have the same indentation as line 32
this needs editing :-
from
to
act.SetVisible(toggle)
Locked Out
andygraph ( ) posted Sun, 30 March 2014 at 8:43 AM
i have repost up
structure ( ) posted Sun, 30 March 2014 at 8:47 AM
Forum Coordinator
if you want the actor to be invisible in the scene SetVisible is the way to go
Locked Out
structure ( ) posted Sun, 30 March 2014 at 8:58 AM · edited Sun, 30 March 2014 at 9:01 AM
Forum Coordinator
    scn.SetFrame(frame)
Locked Out
andygraph ( ) posted Sun, 30 March 2014 at 9:03 AM
now error:
line 6
SyntaxError: invalid syntax
the script:
obj series importer
import poser, os
scn = poser.Scene()
sdir = "C:Users"
frame = 0
print myfiles
try:
print cfile
ActVisible(act,1,0)
frame = frame + 1
scn.SetFrame(frame)
if frame > 2:
scn.SetFrame(frame)
except:
print "Done"
structure ( ) posted Sun, 30 March 2014 at 9:10 AM
Forum Coordinator
there is a colon :  missing off the end of your line
Locked Out
andygraph ( ) posted Sun, 30 March 2014 at 9:15 AM
error here:
line 7
scn.SetFrame(frame)
IndentationError: expected an indented block
the script:
obj series importer
import poser, os
scn = poser.Scene()
scn.SetFrame(frame)
sdir = "C:Users"
frame = 0
print myfiles
try:
print cfile
ActVisible(act,1,0)
frame = frame + 1
scn.SetFrame(frame)
if frame > 2:
scn.SetFrame(frame)
except:
print "Done"
structure ( ) posted Sun, 30 March 2014 at 9:18 AM
Forum Coordinator
this is how I would write it - all the indentations are correct
import poser, os,os.path
scn = poser.Scene()
    scn.SetFrame(frame)
def ImportObj(cfile):
sdir = os.path.join('c:', os.sep , 'users')
frame = 0
print myfiles
if myfile.endswith('.obj'):
    try:
        ImportObj(cfile)
        ActVisible(act,1,0)
        frame += 1
        scn.SetFrame(frame)
        if frame > 2:
        scn.SetFrame(frame)
    except:
        print 'error on ', myfile
print 'done'
Locked Out
andygraph ( ) posted Sun, 30 March 2014 at 9:35 AM
error:
line 32
structure ( ) posted Sun, 30 March 2014 at 9:46 AM
Forum Coordinator
lol - ok - i missed an indent :)
        try:
            ImportObj(cfile)
            ActVisible(act,1,0)
            frame += 1
            scn.SetFrame(frame)
            if frame > 2:
            scn.SetFrame(frame)
        except:
print 'done'
Locked Out
andygraph ( ) posted Sun, 30 March 2014 at 11:39 AM · edited Sun, 30 March 2014 at 11:49 AM
sorry but its the same, whats the difference ?
now import the obj sequence and are all visible and the toggle visible key is not check..
can i send you a example of a poser project
just i need a mail
structure ( ) posted Sun, 30 March 2014 at 12:40 PM
Forum Coordinator
yes - you can,  but what you must understand is that the visible object will remain visible in all frames (the invisible object will remain invisible in all frames) that is to say -
once it is made visible - it will be visible in every frame from start to finish, likewise if it is invisible it will be invisible in all frames.
the only way to use it in an animation is to set it on and off as you need it
i will sitemail you with an email addy.
Locked Out
andygraph ( ) posted Sun, 30 March 2014 at 12:46 PM
yes, the obj is need to be visible only on 1 frame
example:
file.001.obj will be visible only on frame 1 invisible on all other frames
file.002.obj will be visible only on frame 2 invisible on all other frames
file.003.obj will be visible only on frame 3 invisible on all other frames
ecc..
structure ( ) posted Sun, 30 March 2014 at 12:54 PM
Forum Coordinator
are the files all named with numbers?
Locked Out
structure ( ) posted Sun, 30 March 2014 at 1:03 PM
Forum Coordinator
    obj=''
    for frame in frames:
        if act.Name().endswith(frame):
            act.SetVisible(1)
        else:
            act.SetVisible(0)
        try:
            ImportObj(cfile)
            act = scene.CurrentActor()
            act.SetName(act.Name())+'%03d' % frame
            ActVisible(act,1,0)
            frame += 1
            if frame > 2:
                scene.SetFrame(frame - 2)
        except:
Locked Out
structure ( ) posted Sun, 30 March 2014 at 1:35 PM · edited Sun, 30 March 2014 at 1:41 PM
Forum Coordinator
replace
 with
act=scene.CurrentActor()
name=act.Name()+('n%03d') % frame
act.SetName(name)
and replace
with
if act.Name().endswith(str(frame)):
Locked Out
andygraph ( ) posted Sun, 30 March 2014 at 1:59 PM · edited Sun, 30 March 2014 at 1:59 PM
nothing .. its the same .. the objs are visible on all frames and no toggle visible key is checked :-(
structure ( ) posted Sun, 30 March 2014 at 2:04 PM
Forum Coordinator
i willl write a script - and post it shortly
Locked Out
andygraph ( ) posted Sun, 30 March 2014 at 2:09 PM
MANY THX! Structure ;-)
structure ( ) posted Sun, 30 March 2014 at 2:59 PM · edited Sun, 30 March 2014 at 3:09 PM
Forum Coordinator
the reason nothing is changing is because the script is not moving the animation and the animation is not re-drawing.
this script will do that, but it does not account for lights and cameras.
import poser
scene    =    poser.Scene()
frame     =    0
for act in scene.Actors():
    name = act.Name() +  ' - %03d' % frame
    act.SetName(name)
    frame +=1
for f in range(scene.NumFrames()):
    if act.Name().endswith(str(f)):
        scene.SetFrame(f)
        scene.SelectActor(scene.Actor(act.Name()))
        act.SetVisible(1)
    else:
            if not act.Name().endswith(str(f)):
                act.SetVisible(0)
    scene.DrawAll()
Locked Out
andygraph ( ) posted Sun, 30 March 2014 at 3:16 PM
ok, but how can i use this script with import obj sequence script ?
i need only import objs with toggle visible key enable for animation
i dont need light and camera ..
structure ( ) posted Sun, 30 March 2014 at 3:26 PM · edited Sun, 30 March 2014 at 3:27 PM
Forum Coordinator
scn = poser.Scene()
def IsValid(actor):
    if actor !='' and actor !=None:
        if actor.IsLight() or actor.IsCamera():
            return False
        else:
            return True
def ActVisible():
        if IsValid(act):
            act.SetName(name)
            frame +=1
        if act.Name().endswith(str(f-1)) and IsValid(act):
            scene.SetFrame(f)
            act.SetVisible(1)
        else:
                if not act.Name().endswith(str(f-1)) and IsValid(act):
                    act.SetVisible(0)
        scene.DrawAll()
frame = 0
print myfiles
        try:
            ImportObj(cfile)
        except:
ActVisible
print 'done'
Locked Out
andygraph ( ) posted Sun, 30 March 2014 at 3:32 PM
nothing, its the same no visible animation
please can i send to you a example about want i need ?
structure ( ) posted Sun, 30 March 2014 at 3:37 PM
Forum Coordinator
sure thing - i sent you a sitemail earlier
Locked Out
andygraph ( ) posted Sun, 30 March 2014 at 3:54 PM
i send you now a zip file
structure ( ) posted Sun, 30 March 2014 at 4:03 PM
Forum Coordinator
ok
Locked Out
structure ( ) posted Sun, 30 March 2014 at 6:07 PM · edited Sun, 30 March 2014 at 6:08 PM
Forum Coordinator
ok - this should work
import poser , os.path
sdir = os.path.join('c:','users')
def IsValid(actor):
            return False
        else:
            return True
def ImportObj(fName):
    imex = scene.ImExporter()
    options = imex.ImportOptions('obj', None)
    imex.Import('obj', 'File Format Wavefront', fName, options)
actlist=[]
lof=os.listdir(sdir)
for f in lof:
    if f.endswith('.obj'):
        fName = os.path.join(sdir, f)
        try:
            ImportObj(fName)
        except:
            print 'error on ', f
print 'done'
[actlist.append(act) for act in scene.Actors() if IsValid(act)]
la=len(actlist)
for nf in range(la):
    actlist[nf].SetVisible(1)
    scene.SetFrame(nf+1)
    for i in range(la):
        if not i == nf:
            actlist[i].SetVisible(0)
            scene.DrawAll()
    for x in range(10000000):
        x+=1
    x=0
you may need to edit the IsValid function to add more things you do not want to change in your scene
eg.
if actor.Name()=='Ground':
    return False
Locked Out
structure ( ) posted Sun, 30 March 2014 at 6:53 PM
Forum Coordinator
this is what this script does.
Locked Out
andygraph ( ) posted Mon, 31 March 2014 at 2:05 AM · edited Mon, 31 March 2014 at 2:09 AM
error:
line 3, in
NameError: name 'scene' is not defined
but i need run this script then to have import obj sequence ?
because the project will be huge for work then i have import all objs
structure ( ) posted Mon, 31 March 2014 at 2:09 AM
Forum Coordinator
add
scene=poser.Scene()
near top
Locked Out
andygraph ( ) posted Mon, 31 March 2014 at 2:16 AM · edited Mon, 31 March 2014 at 2:17 AM
same error:
line 3, in
this is the script:
scene = poser.Scene ()
sdir = "C:SEQFOLDER"
def IsValid(actor):
return False
else:
return True
actlist=[]
for f in lof:
try:
ImportObj(fName)
except:
print 'done'
la=len(actlist)
for i in range(la):
if not i == nf:
scene.DrawAll()
x+=1
x=0
structure ( ) posted Mon, 31 March 2014 at 2:21 AM
Forum Coordinator
needs to be above
Locked Out
andygraph ( ) posted Mon, 31 March 2014 at 2:26 AM
now import the seq,  but all props are invisible and the last is visible
the toggle visible key is not checked again on all props
structure ( ) posted Mon, 31 March 2014 at 2:32 AM
Forum Coordinator
set the delay
the animation will play, I can't set the key to checked atm, but this script works as you move through the frames - it makes the next prop visible and the last prop invisible.
other than that, I am at a loss to understands what you are after,
Locked Out
andygraph ( ) posted Mon, 31 March 2014 at 2:39 AM · edited Mon, 31 March 2014 at 2:40 AM
x in range is set to (10000000) now
no different is there
the script dont work with me
anyway if the toggle visible key is not checked on any obj in scene no visible animation feature will be there, the real problem has always been there.
structure ( ) posted Mon, 31 March 2014 at 2:43 AM · edited Mon, 31 March 2014 at 2:44 AM
Forum Coordinator
using the toggle visible key is apparently the same as setvisible, I can't find any other way to do this - sorry.
Locked Out
andygraph ( ) posted Mon, 31 March 2014 at 2:44 AM
my idea is import 3d fluid simulation or other 3d simulation into poser through a obj sequence
andygraph ( ) posted Mon, 31 March 2014 at 2:50 AM
"setvisible" dont give animation feature.
For have visible animation is need check the "toggle visible key", first to give any keyframe via script.
just is need know the python command for active the "toggle visible key"
MANY, MANY THX for your time Structure, you are a FRIEND! ;-)
structure ( ) posted Mon, 31 March 2014 at 2:57 AM
Forum Coordinator
there are a few keywords that deal with keyframes
NextKeyFrame
NextKeyFrameAll
PrevKeyFrame
PrevKeyFrameAll
AddKeyFrame
DeleteKeyFrame
(there are probably more than this)
Locked Out
  • 1
  • 2
