Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
I think it defaults to whatever program you have set up to open text files on your system. Personally, I would like to know how to get it to open Idle or some other native Python script editor. Idle is hidden away somewhere and not accessed like other programs, for this sort of thing.... :unsure:
Seems to be flawed in Windows at least, set it to Komodo Edit and tried to open one of the python text files and it fell flat on its face because it doesn't like spaces in directory name (yep its only been 20 years since spaces have been allowed in DOS/Windows directories,guess too soon for it to be supported). Editing the poser ini didn't work. Possibly leaving it blank and associating py file extension with the editor might work better but I've kind of lost interest in hunting down all functions Microsoft have hidden in W7 and W8 that were easily available in XP.
The .pyw works, for Idle! :woot: I have a glaring unfamiliarity with the .pyw format. If a lack of familiarity can glare. :unsure: Never seen the type before. Huh.
Poser Pro 2014 will only allow one to browse for a .exe file, when attempting to set the Python editor in the user preferences, on Wndows. I had to edit the Poser.ini, in order to set up Idle.
PYTHON_EDITOR_PATH "C:Python27Libidlelibidle.pyw"
(I note that we apparently can no longer post text on Rosity in code brackets. Feh. We can certainly format text with plenty of color options, however.... :unsure:)
When I open Idle from within Poser, however, I get the correct Idle window, plus two extra instances of Idle. One is named "Pro" and the other is just "Python Shell". These are irritating, but can simply be closed.
Whoa. Make that four extra Idle windows, and I don't remember the names of the last two. Might have been "Poser" and "Micro". Kind of goofy. Don't like that it does this. Hmm.
Does the python editor have a default option...What should it be set to for the best result?
