Fri, Jan 31, 7:01 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 3:43 am)
Subject: Why is this happening?
rokket ( ) posted Sat, 22 February 2014 at 10:29 PM · edited Fri, 31 January 2025 at 7:01 AM
I import the suit into Poser.
I enter the setup room and apply Dawn's DEV rig
I got back into the pose room and click 'conform to' Dawn
And it explodes.
WHY????
PhilC ( ) posted Sun, 23 February 2014 at 1:41 AM
Suggest that you now use the Poser figure menu to copy the joint zones from Dawn.
rokket ( ) posted Sun, 23 February 2014 at 8:06 AM
I'll try that. Thanks Phil.
rokket ( ) posted Sun, 23 February 2014 at 8:16 AM
Nope. Same result. I've never encountered this problem before and I don't understand what is causing it. It's pretty frustrating.
PhilC ( ) posted Sun, 23 February 2014 at 9:49 AM
Is the suit correctly grouped?
rokket ( ) posted Sun, 23 February 2014 at 10:04 AM
Quote - Is the suit correctly grouped?
I used the option to group it according the the new bones in the setup room. I will try to autogroup it in the pose room and see what happens. There is a lot of geometry there, and I don't want to manually group it. But if I have to...
Thanks for the help, Phil. You are a saint.
rokket ( ) posted Sun, 23 February 2014 at 10:11 AM
Yeah, that didn't work either. I have a feeling I got something screwed up with the modeling and nothing is going to work because there is a conflict somewhere with my polygons and edge looping.
vilters ( ) posted Sun, 23 February 2014 at 10:49 AM
Is some of the geometry intersecting with other parts?
rokket ( ) posted Sun, 23 February 2014 at 10:59 AM
It was. I used the shell extrude function in Wings to create the chest, abdomen and crotch pieces. I went back in and scaled them away from the suit so there were no intersections but it still exploded.
vilters ( ) posted Sun, 23 February 2014 at 11:02 AM
Another thing to check.
Is Poser Skinning method set to Unimesh or Traditional Skinning?
rokket ( ) posted Sun, 23 February 2014 at 11:03 AM
Hmmm... how do I check that?
vilters ( ) posted Sun, 23 February 2014 at 11:05 AM
Top menu row
Figure => Skinning Method => Set to Poser Traditional.
If no go? Feel free to send the object file over.
rokket ( ) posted Sun, 23 February 2014 at 11:07 AM
I am running a render right now, so as soon as that is done, I'll check and let you know.
rokket ( ) posted Sun, 23 February 2014 at 11:09 AM
That option isn't available in Poser 9. So that's not it.
rokket ( ) posted Sun, 23 February 2014 at 11:34 AM
One more thing I am going to try: I am going to break the suit into 4 parts; an underarmor, an exoskeleton, boots and helmet and see what happens there. If nothing good comes of it, I will just scrap it.
rokket ( ) posted Sun, 23 February 2014 at 11:53 AM · edited Sun, 23 February 2014 at 11:53 AM
I found an issue that may be behind the problem, but I don't know how to fix it.
The scale is set at 200% and I can't change it. I can make it bigger but not smaller. How do I correct this? Edit the cr2?
vilters ( ) posted Sun, 23 February 2014 at 12:05 PM
I think you need to check the export options in Wings.
Sorry, but I use Blender for modeling.
rokket ( ) posted Sun, 23 February 2014 at 12:10 PM
I did check all that. Everything imports into Poser just fine. There may be something wrong with Dawn's DEV rig, so I am going to take a look at that in my cr2 editor and maybe I can get this fixed.
rokket ( ) posted Sun, 23 February 2014 at 1:12 PM
I went over to the Hivewire forum and posted my problem there. It turns out that paganeagle2001 had already posted a fix to the problem. You have to click on 'include scales when conforming' or it explodes. Problem solved!
722 ( ) posted Sat, 29 March 2014 at 3:37 PM
Yes i was have this problem  ya it is fix i happy i found this thred
