Or you could create a mask with a soft edge to exclude the face from the shiny shader...
EDIT scroll down to BB's post with the Phantom of the Opera-like mask here...
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3131278
"Oh - the manual says that? I have never read the manual - this must be why."This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
this render is in low resolution, but help to show the problem.
M4 has the oiled body, except for the face and neck.
the problem is the conjunction of the skin between the neck and the rest of body.
as you can see in the render there is a trace net, because they are two different parts of the skin.
how can I do to fix it without using postwork?
A trans map?
ideas ?
thanks
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
