Sun, Feb 16, 1:00 PM CST
Subject: Poser Ground Plane/Prop
Nukeboy ( ) posted Mon, 10 March 2014 at 4:29 PM · edited Mon, 03 February 2025 at 9:13 AM
Okay, I'm sure it's been discussed, but I can't find a thread.  How do you get the ground plane/prop to totally disappear in Poser 10?  If I clear everything on a blank page, the ground disappears, as soon as I load a prop, it's back... Here's my screen shot:
willyb53 ( ) posted Mon, 10 March 2014 at 4:57 PM
Ctrl G for on/off
Bill
Nukeboy ( ) posted Wed, 12 March 2014 at 10:50 AM
Nope.  Ground plane is still visible in the preview window.  As before, it doesn't render, but in preview, it still obscures anything below it.
Any other ideas?
Miss Nancy ( ) posted Wed, 12 March 2014 at 12:01 PM
nuke, it should turn ground invisible but leave default shadow.  uncheck "ground shadows".  can't duplicate yer issue, other than that, like some other plane near ground.
aRtBee ( ) posted Wed, 12 March 2014 at 12:29 PM
ground plane is behaving fine with me, sorry.
EClark1894 ( ) posted Thu, 13 March 2014 at 7:07 PM
Quote - Ctrl G for on/off
Bill
If you're using a Mac that would be Command G. Command is that little clover style symbol on the keyboard. Alternatively, you could select the Property tab  and simply uncheck everything.
Nukeboy ( ) posted Fri, 14 March 2014 at 8:44 PM
Still doesn't work.  If I open a new scene with nothing in it, the ground plane goes away.  As soon as I add a Prop, the Ground plane appears in my preview window with all of the selections unselected... BTW I'm running a PC with Vista (cry for me Argentina... at least it's not W8!).
RedPhantom ( ) posted Sat, 15 March 2014 at 9:18 AM
Site Admin
It looks like your ground shadows are on. They will show up even when the ground is turned off. Under the display uncheck ground shadows or use the third icon from the left  just under your image.
Nukeboy ( ) posted Sat, 15 March 2014 at 2:06 PM
Bingo!!! Thanks!  This was really driving me nuts (not because it's annoying, but I couldn't figure it out!).  Okay, too many exclamation points....
RedPhantom ( ) posted Sat, 15 March 2014 at 6:31 PM
Site Admin
glad to help.
