Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 3:46 am)
Thanks, so they've start fixing their fixes...
Every now and then I run into an update which won't install automatically on my Win7-64.
In most cases, it helps when I download the update files manually from following the update-error-messages, it must be soms 64bit/access-authority thing. In rare cases, the update won't install manually either, then I check the ignore option. After soms time MS issues a new fix, including the older issues, which does install.
BTW/1 I never let Windows install updates automatically by itself, it only might do so at my command. Some updates are interfering with Poser use, or with Poser overnight render jobs (performing a system restart and alike...)
BTW/2 Automatic updates on the Vista-32 machine run fine, though. That is, recent ones seem to generate conflicts with the - latest but old - nvidia driver for the Ti560GS card, causing BSOD at startup. I had to shut down the driver completely to handle that. According to the net, the issue appears for all versions of that 560 driver. So be informed.
all the best...
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
The headline phrase "Fixes update errors" can be taken two ways, and the other way is probably most appropriate.,...
Don't run your computer with old-fashioned errors! MS gives you the latest and greatest *brand-new errors! *
My python page
My ShareCG freebies
Quote - Don't run your computer with old-fashioned errors! MS gives you the latest and greatest *brand-new errors! *
Truer words are rarely spoken... :lol:
"Oh - the manual says that? I have never read the manual - this must be why."This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
My wife was having problems today with some Windows 7 updates refusing to install. I Googled the error code and came up with this article. The "System Update Readiness Tool" download seems to have fixed the issue...
Fix Windows Update corruption errors such as 0x80070002 and 0x80070057
Windows Update corruption errors prevent Windows updates and service packs from installing. For example, an update might not install if a system file is damaged. If the error you see is in the following list, try the solution in this article.
0x80070002 | 0x8007000D | 0x800F081F | 0x80073712 | 0x800736CC | 0x800705B9 | 0x80070246 | 0x8007370D | 0x8007370B | 0x8007370A | 0x80070057 | 0x800B0100 | 0x80092003 | 0x800B0101 | 0x8007371B | 0x80070490
If your error is not listed or if your are running Windows XP, try the Windows Update Troubleshooter.
Resolution#### Windows 8.1, Windows 8, Windows Server 2012 R2 or Windows Server 2012
To resolve this problem, use the inbox Deployment Image Servicing and Management (DISM) tool. Then, install the Windows update or service pack again. 1. Open an elevated command prompt. To do this, swipe in from the right edge of the screen, and then tap Search. Or, if you are using a mouse, point to the lower-right corner of the screen, and then click Search. Type Command Prompt in the Search box, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
NoteIt may take several minutes for each command operation to be completed. - DISM.exe /Online /Cleanup-image /Scanhealth
DISM creates a log file (%windir%/Logs/CBS/CBS.log) that captures any issues that the tool found or fixed. %windir% is the folder in which Windows is installed. For example, the %windir% folder is C:Windows.
Windows 7, Windows Vista, Windows Server 2008 R2 or Windows Server 2008
To resolve this problem, use the System Update Readiness tool. Then, install the Windows update or service pack again.Download the System Update Readiness tool.
Click the download link in the following table that corresponds to the version of Windows that is running on your computer.
http://support.microsoft.com/kb/947821
"Oh - the manual says that? I have never read the manual - this must be why."“I could buy better software, but then I'd have to be an artist and what's the point of that?"
