Mon, Nov 25, 3:25 PM CST
Subject: how do I make the flashlight look like it has light coming from it?
curtskinn ( ) posted Sun, 23 March 2014 at 11:01 AM · edited Mon, 25 November 2024 at 1:18 PM
I have a character holding a flashlight in her left hand, and I am wanting to make it look like the flashlight is on, but am not sure how to get the lighting right for it.
Any ideas or suggestions?
hborre ( ) posted Sun, 23 March 2014 at 11:10 AM
Right now, this is the latest solution/suggestion:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2879138
cedarwolf ( ) posted Sun, 23 March 2014 at 1:14 PM
I'll be following this and experimenting myself.
seachnasaigh ( ) posted Thu, 27 March 2014 at 5:59 AM
     Who knows how to save a light with a prop?  I vaguely recall that it can be done.
     I'll make a flashlight with a beam (visibility will fade away near the far end of the cone).  The lens will be moderately ambient.  The lighting will need to be from a spotlight set to match the cone angle.
     Geometry build screen capture attached - ignore scale;  I'll set that before exporting OBJs.
parkdalegardener ( ) posted Thu, 27 March 2014 at 7:37 AM
You can indeed save a light parented to a prop but you have to edit the prop code and add in the light code. I haven't done it in a while but could check my notes for you. Also try a search here with Lesbently as the author of the posts. I believe it was he that showed me how some time back.
parkdalegardener ( ) posted Thu, 27 March 2014 at 3:15 PM
I looked in my notes and Les's instructions were posted Fri Sept 3 2004
