Forum Moderators: RedPhantom
According to your setting you have the beard completely transparent. Set the transparency to either 1 or 0.9, then set your transparency edge to a setting between 0.1 and 0.9... Your transparency fall off should be set to 0.5 or 0.6 ... My numbers are just suggestion but you really should have your transparency setting no greater than 1.
I have M3 beard and my mat room setting is 1 for transparency, 0.7 for the transparency edge and 0.6 for the transparency fall off. Ray tray is enabled in the render setting. Hope this helps.
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Quote - According to your setting you have the beard completely transparent. Set the transparency to either 1 or 0.9, then set your transparency edge to a setting between 0.1 and 0.9... Your transparency fall off should be set to 0.5 or 0.6 ... My numbers are just suggestion but you really should have your transparency setting no greater than 1.
Okay. Thank you.
Also change the filtering on the texture & trans maps to "crisp" on all the materials. You'll notice a difference.
If you really want to get fancy, I plug the trans maps into the bump map channels. Play with the strengths depending on your focus length. It can really help make the beard "pop".
Poser Pro 2012 SR3 on Win10 x64 w/Reality.
Poser Display Units = inches.
Quote - Also change the filtering on the texture & trans maps to "crisp" on all the materials. You'll notice a difference.
Okay. Thank you.
Do you have the gamma set to 1 on all transparency maps of of the materials of the beard? There is a script on the Scripts menu that can change it all for you easily; under Material Mods you will find ChangeGamma. Select the beard, run the script, and enter the the value 1.0, select current figure on the next menu and all of the above on the last menu....
"Oh - the manual says that? I have never read the manual - this must be why."Quote - Do you have the gamma set to 1 on all transparency maps of of the materials of the beard? There is a script on the Scripts menu that can change it all for you easily; under Material Mods you will find ChangeGamma. Select the beard, run the script, and enter the the value 1.0, select current figure on the next menu and all of the above on the last menu....
Both the texture map and the trans map are both set to 1 on the gamma setting. I may have to run the sc ript to get it to take effect. Unfortunately, the comp is going inthe shop tomorrow and I won't have it back till Friday. I'm trying to come up with an answer that will prevent 2014 from crashing every few sec onds. It took me 6 tries to get this latest test rendered.
You don't want the texture maps set at 1, just the trans maps (and bump maps if any). Texture maps should be set to get the value from render settings.....
"Oh - the manual says that? I have never read the manual - this must be why."SceneFixer, EZSkin and other cool stuff can be dowloaded here...
"Oh - the manual says that? I have never read the manual - this must be why."This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I use- trying to use- Poser Pro 2014. How can I get M3's beard less transparent and fuller- more like it's unrendered look?
