Mon, Feb 17, 8:14 PM CST
Forum Moderators: RedPhantom
Subject: M3 Beard
mdbruffy ( ) posted Sun, 06 April 2014 at 8:07 PM · edited Sat, 25 January 2025 at 10:55 PM
I use- trying to use- Poser Pro 2014. How can I get M3's beard less transparent and fuller- more like it's unrendered look?
Medzinatar ( ) posted Sun, 06 April 2014 at 8:14 PM
change gamma on transmaps to 1.0
mdbruffy ( ) posted Sun, 06 April 2014 at 8:28 PM
Uh, what Gamma?
shvrdavid ( ) posted Sun, 06 April 2014 at 9:35 PM
Click on the texture name in the node you have outlined, then in the box that comes up set the gamma to one.
mdbruffy ( ) posted Sun, 06 April 2014 at 9:43 PM
Quote - Click on the texture name in the node you have outlined, then in the box that comes up set the gamma to one.
Okay, Thank you.
ThunderStone ( ) posted Sun, 06 April 2014 at 9:44 PM
According to your setting you have the beard completely transparent. Set the transparency to either 1 or 0.9, then set your transparency edge to a setting between 0.1 and 0.9... Your transparency fall off should be set to 0.5 or 0.6 ...  My numbers are just suggestion but you really should have your transparency setting no greater than 1.
I have M3 beard and my mat room setting is 1 for transparency, 0.7 for the transparency edge and 0.6 for the transparency fall off. Ray tray is enabled in the render setting. Hope this helps.
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
mdbruffy ( ) posted Sun, 06 April 2014 at 10:16 PM
Quote - According to your setting you have the beard completely transparent. Set the transparency to either 1 or 0.9, then set your transparency edge to a setting between 0.1 and 0.9... Your transparency fall off should be set to 0.5 or 0.6 ...  My numbers are just suggestion but you really should have your transparency setting no greater than 1.
Okay. Thank you.
Taren421 ( ) posted Sun, 06 April 2014 at 11:36 PM · edited Sun, 06 April 2014 at 11:42 PM
Also change the filtering on the texture & trans maps to "crisp" on all the materials. You'll notice a difference.
If you really want to get fancy, I plug the trans maps into the bump map channels. Play with the strengths depending on your focus length. It can really help make the beard "pop".
Poser Pro 2012 SR3 on Win10 x64 w/Reality.
Poser Display Units = inches.
mdbruffy ( ) posted Mon, 07 April 2014 at 4:03 AM
Quote - Also change the filtering on the texture & trans maps to "crisp" on all the materials. You'll notice a difference.
Okay. Thank you.
mdbruffy ( ) posted Mon, 07 April 2014 at 6:04 PM
Gamma is at 1.0
Transparency is at 0.9
Transparency edge is at 0.7
Transparenct fall off is at 0.6
And it's still not what it should be.
WandW ( ) posted Mon, 07 April 2014 at 9:27 PM
Do you have the gamma set to 1 on all transparency maps of of the materials of the beard?  There is a script on the Scripts menu that can change it all for you easily; under Material Mods you will find ChangeGamma.  Select the beard, run the script, and enter the the value 1.0, select current figure on the next menu and all of the above on the last menu....
mdbruffy ( ) posted Mon, 07 April 2014 at 9:41 PM
Quote - Do you have the gamma set to 1 on all transparency maps of of the materials of the beard?  There is a script on the Scripts menu that can change it all for you easily; under Material Mods you will find ChangeGamma.  Select the beard, run the script, and enter the the value 1.0, select current figure on the next menu and all of the above on the last menu....
Both the texture map and the trans map are both set to 1 on the gamma setting. I may have to run the sc ript to get it to take effect. Unfortunately, the comp is going inthe shop tomorrow and I won't have it back till Friday. I'm trying to come up with an answer that will prevent 2014 from crashing every few sec onds. It took me 6 tries to get this latest test rendered.
WandW ( ) posted Mon, 07 April 2014 at 9:46 PM · edited Mon, 07 April 2014 at 9:47 PM
You don't want the texture maps set at 1, just the trans maps (and bump maps if any).  Texture maps should be set to get the value from render settings.....
mdbruffy ( ) posted Mon, 07 April 2014 at 10:04 PM
Quote - You don't want the texture maps set at 1, just the trans maps (and bump maps if any).  Texture maps should be set to get the value from render settings.....
OKay. I misunderstood. I'll fix that when I get the comp back on Friday.
WandW ( ) posted Tue, 08 April 2014 at 11:15 AM · edited Tue, 08 April 2014 at 11:17 AM
Here's a quick render I did.  The skin is from DAZ' Men of the Year with EZSkin shader, render GC at 2.2 and no IDL, and the lighting is the default PP2014 lights.   I loaded the beard, (no, Vicky is NOT his beard!  :lol: ) applied the dark colour MAT pose, applied the Full A-01 MAT pose, and ran the ChangeGamma script as noted above.  I then set the texture filtering to crisp using Snarly's SceneFixer.
SceneFixer, EZSkin and other cool stuff can be dowloaded here...
http://snarlygribbly.org/3d/forum/
mdbruffy ( ) posted Tue, 08 April 2014 at 3:14 PM
Okay. The comp's in the shop now. I'll try this when I get it back.
