Wed, Sep 18, 2:29 PM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 18 7:39 am)
Subject: Accessing black line on poser graph?
ninhalo5 ( ) posted Thu, 10 April 2014 at 3:49 PM · edited Wed, 18 September 2024 at 2:27 PM
Hi guys,
Is there anyway possible to access the black line that's showing on my graph? I know sometimes this shows due to different layers, but this isn't one of the times. I have 2 layers currently and they both show this same line. I'm thinking it might be caused by an animated pose I applied, but can't figure it out. Theres a crook between frame 1 and 2 that's causing me havoc.
Thanks
PhilC ( ) posted Thu, 10 April 2014 at 4:33 PM
You should be able to mouse over it and grab it.
ninhalo5 ( ) posted Thu, 10 April 2014 at 4:39 PM
Quote - You should be able to mouse over it and grab it.
Hi Phil, actually the black line is inaccessible, only the red is adjustable as is.
In normal conditions, the black line represents that perticuler body part on another layer. What was confusing me is that the line stayed the same in this instance no matter which layer I was on.
I did just accidently figure it out I believe. I switched the Composite method radio button to add then back to replace and it created a new red line that when I adjust it the black adjusts with it.
perhaps I'm glitched lol.
Thanks for the reply
nathank3d ( ) posted Sat, 12 April 2014 at 11:31 AM
Do you have more than one layer?
ninhalo5 ( ) posted Sat, 12 April 2014 at 1:30 PM
Yeah,  but the layers weren't at fault. This instance the line was caused by an animated pose file. I knew normally that line showed what is going on on other layers. Seems some poses will also create those lines.
