playing with blurring things to root them to the scene, it's a complicated learning curve since i'm used to wanting things to be crystal clear and in full color.
in one image it's clear the others been blurred, as you can see the blurred one looks as if they are there the clear one, they seem to be not really there, like floating above the background set.
Think I found the right lighting and formula for making the characters look photo realistic on the bridge set, one trick is to reduce the color satuaration with a gray scale alpha channel which brings up the shadow threshold.
I also opted to change the displays to be more bluish and reduced the color saturation on those as well.
some of the images here wont show that because I did those before I thought of it.
