Sat, Nov 30, 10:24 PM CST
Subject: Texture stretching....grrrrrr
rokket ( ) posted Sat, 12 April 2014 at 8:37 AM · edited Sat, 30 November 2024 at 10:22 PM
I tried to search and see if this was covered, but most of the posts that turned up were just pointing it out.
How can I fix texture stretching? I am using Wings 3D and UVMapper classic, so I don't have a huge load of flexible options.
I am experimenting with making slinky unmentionables. I was happy with it until I saw this.
Nudity tagged, just to cover the bases.
PhilC ( ) posted Sat, 12 April 2014 at 9:11 AM
You are going to be limited by the software that you are using. It looks like you are planar mapping, try cylindrical in the Y axis with no caps.
Or if you would like to send me the OBJ file I'll be happy to UV map it for you in UV Layout Pro. Will only take a couple of minutes.
rokket ( ) posted Sat, 12 April 2014 at 9:16 AM
I'll give your suggestion a shot and see what happens. I may look into buying a good program later this year.
Ian Porter ( ) posted Sat, 12 April 2014 at 9:16 AM
You could try Roadkill
http://www.pullin-shapes.co.uk/page8.htm
It is a free UVmapping tool that can unfold a mesh to create a UV map with minimal distortion.
shvrdavid ( ) posted Sat, 12 April 2014 at 9:26 AM
I use Blender to do most of my UV mapping.
It is free, but has a steep learning curve to learn he whole program.
The UV part of it requires that you know some of the modeling options to add seams, but it is not that hard to learn.
booksbydavid ( ) posted Sat, 12 April 2014 at 11:44 AM
I've just acquired 3dCoat. It's UV mapping is amazingly easy and results are incredible. I modeled a whole figure and with 3dCoat's UV tools I had seams marked and a good quality map made in a matter of a few minutes with no stretching. It's a bit expensive, but it does do a whole lot more then UV maps. :)
maxxxmodelz ( ) posted Sat, 12 April 2014 at 11:59 AM
+1 for 3dCoat. It's the best in the industry outside of Mari.  The autounwrap is surprisingly fast and accurate, with ZERO texture stetching.
booksbydavid ( ) posted Sat, 12 April 2014 at 6:06 PM
The new version of 3dCoat has a button you push that automatically evens out your UVs. It's great.
rokket ( ) posted Sun, 13 April 2014 at 3:18 AM · edited Sun, 13 April 2014 at 3:19 AM
Well, as it turns out, Phil's suggestion did the trick.
Now I need to get the textures right and I will release this one.
Nudity tagged just in case...
rokket ( ) posted Sun, 13 April 2014 at 5:41 AM
Quote - You could try Roadkill
I downloaded Roadkill. I've heard it mentioned before, but I haven't tried it yet. I am going to read through the manual before I do anything with it.
Thanks for the link.
EnglishBob ( ) posted Mon, 14 April 2014 at 7:09 AM · edited Mon, 14 April 2014 at 7:10 AM
Attached Link: How to UV map clothing
> Quote - I downloaded Roadkill. I've heard it mentioned before, but I haven't tried it yet. I am going to read through the manual before I do anything with it.
You may find my tutorial useful, also.
