Mon, Jan 20, 10:18 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
Subject: Nea 3 makes a step back
  • 1
  • 2
pitklad ( ) posted Wed, 02 April 2014 at 4:03 AM · edited Mon, 20 January 2025 at 10:16 AM
Nea 3 would be a total reshape of the face area with a lot of polygons slides
There is a post back from 2012 with the WIP
However since this would make all existing morphs and textures break this should be shifted to  version 4 with new morphs and UV.
So Nea 3 will be mostly an update to include the changeable UV between Victoria 2 and Posette skins plus some alternative geometry body parts
Some work has been done to the face shape but not in polygons position
My FreeStuff
pitklad ( ) posted Wed, 02 April 2014 at 4:06 AM
Micro corrections on the nostrils, eye and lip area
As a reminder I have to mention that Nea is a figure based on Poser 4 woman Posette
A low resolution mesh for todays standards that accepts Victoria 2 textures
My FreeStuff
pitklad ( ) posted Wed, 02 April 2014 at 4:22 AM
A non texture comparison
My FreeStuff
booksbydavid ( ) posted Wed, 02 April 2014 at 11:47 AM
Cool!
momodot ( ) posted Wed, 02 April 2014 at 5:21 PM
Nice!
pitklad ( ) posted Fri, 18 April 2014 at 9:30 AM
Hello everyone, sorry for the slow updates
Here is Nea 3 with the alternative suit and stockings option
My FreeStuff
pitklad ( ) posted Fri, 18 April 2014 at 9:34 AM
And here is the sculp and ear reworked shape
My FreeStuff
booksbydavid ( ) posted Fri, 18 April 2014 at 10:37 AM
Looking good.
momodot ( ) posted Fri, 18 April 2014 at 12:12 PM
Looks great!!
Alisa ( ) posted Fri, 18 April 2014 at 1:57 PM
Very cool :)
Cheers,
Alisa
RETIRED HiveWire 3D QAV Director
pitklad ( ) posted Sat, 19 April 2014 at 2:24 AM
another side by side comparison between Nea 2 and Nea 3 the changes are subtle but I believe give a smoother look and add realism
My FreeStuff
pitklad ( ) posted Sat, 19 April 2014 at 2:53 AM
This is the progress of the whole Nea Project from Posette with Victoria 2 skin to Nea 1 and than to Nea 1 P4 that was a morph For the Nea 1 with Posette skin This was the base for Nea 2 and here we are today at Nea 3
My FreeStuff
momodot ( ) posted Sat, 19 April 2014 at 8:44 AM
I like the slightly less angular bone structure on Nea 3.
pitklad ( ) posted Sat, 19 April 2014 at 8:57 AM
I am also thinking about making small changes on the body shape
but I'm afraid that Posette cloths wouldn't fit perfectly than...
My FreeStuff
booksbydavid ( ) posted Sat, 19 April 2014 at 7:44 PM
Really do like the changes to Nea 3 face. Very nice.
momodot ( ) posted Sat, 19 April 2014 at 9:01 PM
you should go for it and make the figure exactly as you want it. Poser 4 clothes are robust and scale well. If you make JP changes the clothes should work with rigging from a donor CR2.
pitklad ( ) posted Sun, 20 April 2014 at 6:28 AM
I am not gonna tweek the JP, just the shape of the body
maybee I'll do that and include shapes to go back to Posette shape
I would love to try weightmaps on Nea but is seams like it needs a lot of time to setup
My FreeStuff
MarianneR ( ) posted Sun, 20 April 2014 at 11:01 AM
Maybe you could try weightmapping only the big joints, like shoulders and thighs and not bother with the fingers for example.
pitklad ( ) posted Sun, 20 April 2014 at 2:29 PM
MarianneR  I agree with you about partial weightmaping
I'll have to search for tutorials about this as the automatic method converts all the joints at once
My FreeStuff
MarianneR ( ) posted Sun, 20 April 2014 at 2:42 PM · edited Sun, 20 April 2014 at 2:42 PM
Select a body part, say the thigh, and open the joint editor. Choose Bend, Twist or Side-Side.
Press the button "Add" and you get four choices, the last one is "Merge Zones to Weight Map". Then you can start painting. :)
I tried this a bit with the P7 Kate figure but didn't have the patience to finish it.
Edited to add that this is PoserPro 2014
pitklad ( ) posted Sun, 20 April 2014 at 3:01 PM
Thanks for the image this will help me to start! I have loaded some weighmaped figures but never used them at the extend to understand how they workand how clothes work with them
For now there is still job to be done with the third version of Nea
I'm reworking the body UV to accept Victoria 2  textures better than previous Nea versions
Also as soon as I get to the final face shape all existing morphs should be tested and if nessesary reworked or deleted
I'll post the body changes in the next days
My FreeStuff
booksbydavid ( ) posted Sun, 20 April 2014 at 9:07 PM
Weight mapping in Poser isn't difficult, but it does take a bit of practice. The good thing is you can work on one side and then use symmetry to take care of the other side. Saves a lot of frustration. :)
pitklad ( ) posted Tue, 22 April 2014 at 11:35 AM
Does the weight map information gets stored on the character file? So that the same file can work with other obj files too?
By the way here is a preview of the alternative animal feet
My FreeStuff
MarianneR ( ) posted Tue, 22 April 2014 at 2:41 PM
Yes, the weight map info is in the cr2.
pitklad ( ) posted Tue, 22 April 2014 at 4:36 PM · edited Tue, 22 April 2014 at 4:37 PM
Cool thank you! So I can make changes on the base obj while working on the weight map...
Here are the body changes I'm thinking to include on this version
My FreeStuff
pitklad ( ) posted Tue, 22 April 2014 at 5:07 PM
And a front view
The  buttock got smoother and tighter
At first I also lifted those a bit bur Posette has long thighs and they looked even longer
The thorax is narrower but waist kept at the same size as it is a Posette signature body shape part
My FreeStuff
pitklad ( ) posted Tue, 22 April 2014 at 5:17 PM
Finaly a side view
My FreeStuff
booksbydavid ( ) posted Tue, 22 April 2014 at 11:11 PM
The changes to the neck make a nice difference. Looks much better.
ima70 ( ) posted Thu, 24 April 2014 at 4:25 PM
Great work as always! I like the lips shape in Nea3 looks very natural
pitklad ( ) posted Thu, 24 April 2014 at 5:01 PM
ima70! how are my friend? it's been a long time I heard from you!
Thank you and everyone else for the nice comments!
My FreeStuff
pitklad ( ) posted Sun, 27 April 2014 at 3:34 AM
I started remapping UV using Blender's excellent tools
Here is a before-after image of the feet
My FreeStuff
mylemonblue ( ) posted Tue, 29 April 2014 at 12:12 AM
Those improvements look fantastic. Thanks for showing us the update. (^o^)b
My brain is just a toy box filled with weird things
pitklad ( ) posted Tue, 29 April 2014 at 2:44 AM · edited Tue, 29 April 2014 at 2:50 AM
I'm glad you like those
It is fun for me and also works as a diary of the WIP and maybee keeps me from abandoning the project
Updates may take time but this post keeps them together :)
My FreeStuff
shante ( ) posted Sat, 21 November 2015 at 1:06 PM · edited Sat, 21 November 2015 at 1:15 PM
Nice to see you still at making Posette like figures better. Reworking her to use V2 textures is a great offering. Posette had some ugly body bends on her so I am wondering if these changes are going to fix some of them. It will be nice seeing how she will render in the newer Poser versions. Of course just adding V2 textures will not be enough to make her stand proud beside V4 but good textures bumps and reflection mapping should do the trick if the body shapes are brought up to speed. look forward to seeing what you do for her.
BTW the hot link to your freestuff age does not work.
EldritchCellar ( ) posted Sat, 21 November 2015 at 2:43 PM
He probably moved on from "community" participation, it's a small pool. Notice he no longer has an avatar? He used to. Indicates he deleted it.
Boni ( ) posted Sat, 21 November 2015 at 4:10 PM
Know if this figure (character for Posette) is available anywhere?
Boni
EldritchCellar ( ) posted Sat, 21 November 2015 at 11:41 PM
I have version 2 I think, don't think it's available anymore. Used to be at sharecg, no longer. It was a RTEncoded customization (in progressive versions) of Posette. There should be some threads buried here somewhere from a couple few years ago and there's some dead links and discussions at Posette Forever.
WandW ( ) posted Sun, 22 November 2015 at 11:46 AM · edited Sun, 22 November 2015 at 11:53 AM
I have Nea 2.12, and a couple of morphs and characters for her. I can put these on my Google Drive if anyone wants her, as the zips are redistributable...
EDIT: She can be gotten here: 😃
https://drive.google.com/folderview?id=0B9_I3V6UTuuXZlpXYjNoYlB4Zk0&usp=sharing
EldritchCellar ( ) posted Sun, 22 November 2015 at 12:31 PM
That's cool of you WandW, didn't realize they were redistributable. Would be a shame to see all of Pitklad's work on that project disappear into obscurity...
AetherDream ( ) posted Sun, 22 November 2015 at 10:17 PM
It is always interesting to see the work that people can do with the older meshes. Very artistic.
"People who attempt define what art is or is not, are not artists"---Luminescence
pitklad ( ) posted Thu, 26 November 2015 at 7:01 PM
Hello everyone! Thanks for your interest on Nea! It was quite a surprise to see this post revive! I've merged all the Nea 2.12 free stuff on a bundle You can find the file here:
Nea 2.12 bundle
I may pack Nea 3 at the current state as a beta the next days also
have fun!
My FreeStuff
EldritchCellar ( ) posted Fri, 27 November 2015 at 2:50 PM
Cool, nice to hear from you Pitklad.
pitklad ( ) posted Thu, 06 October 2016 at 5:36 PM
Hello everyone! It's been almost one year, the last month I've got some spare time so here is a preview of the new male morph Maybe I'll also update Zenon alongside Nea 3 brother-and-sister.jpg
My FreeStuff
seachnasaigh ( ) posted Thu, 06 October 2016 at 11:05 PM
They both look good, pitklad. Bravo!
Jules53757 ( ) posted Fri, 07 October 2016 at 3:42 AM
Cool!
Ulli
ghostship2 ( ) posted Sat, 08 October 2016 at 11:41 PM
Online Now!
cool!
pitklad ( ) posted Sat, 20 January 2018 at 12:20 PM · edited Sat, 20 January 2018 at 12:34 PM
Hello everyone! I didn't want to make any more teasers or wip posts
This time I have a download link for you
Nea 3 aeonia is up!
Please if anyone has a problem with installation let me know
Thanks again for your interest an support!!
My FreeStuff
SamTherapy ( ) posted Sat, 20 January 2018 at 1:06 PM
Crikey! Many thanks for this. I'll get right to it.
SamTherapy ( ) posted Mon, 22 January 2018 at 1:49 AM
Installation works fine, thanks!
One weirdness I have noticed is the poses force a geometry switch from Hip 0 to Hip 1, which makes the texture look strange.
pitklad ( ) posted Mon, 22 January 2018 at 4:36 AM · edited Mon, 22 January 2018 at 4:39 AM
SamTherapy you are right, it seams that poser includes the geometry change channel of the poses.
So when you use Posette skin body dial for example it tweaks it.
I'll update it ASAP. Thank you so much for the feedback!
My FreeStuff
SamTherapy ( ) posted Mon, 22 January 2018 at 7:56 AM
You're a star. Many thanks.
  • 1
  • 2
