Sun, Feb 9, 4:38 AM CST
Subject: Clothing for She Freak V4
timewyrm ( ) posted Sun, 04 May 2014 at 2:37 PM · edited Sun, 09 February 2025 at 4:37 AM
Is it possible to get clothing to fit She Freak V4?  I tried injecting the morph into the bodysuit, but whilst it appeared as a dial it had no effect.
EClark1894 ( ) posted Sun, 04 May 2014 at 2:55 PM
I believe the morphs have to be "built into" the suit to work. I never had She-freak (any version) cause frankly I thought she was a waste of time and effort, so I'm only going by what I recall of other morphs for V4 like Aiko, the Girl and Stephanie. Hope that helps.
aldebaran40 ( ) posted Sun, 04 May 2014 at 3:24 PM
if you have poser 2014, you  can use the fitting room , a external script like "Morphing Clothes" or "crossdresser 4.0" (a friend used this latter and conforms) I could do that that you want ( Since I not used any of them so I can not advise any )
I particularly fix the clothes in zbrush so I do not know if it's an option that can help you.
I've found very useful for "extreme" big muscles,non conventional bodies , characters  giant breasts etc ... is the dynamic clothing, with a little practice it makes clothes that fit well with your models also
Medzinatar ( ) posted Sun, 04 May 2014 at 3:46 PM · edited Sun, 04 May 2014 at 3:52 PM
In PoserPro2014, I just copied morphs from SheFreak to bodysuit and it works fine. Just make sure you have "include morphs" checked in properties panel under "when conforming"
timewyrm ( ) posted Sun, 04 May 2014 at 4:11 PM
Thanks everyone - Im still using Posr 9. Might be time for an upgrade then......
EClark1894 ( ) posted Sun, 04 May 2014 at 4:52 PM
The fitting Room is a feature in PP2014 only, I believe, if you upgrade.
vilters ( ) posted Sun, 04 May 2014 at 5:33 PM
"Copy Morphs from" is only available in PP2014.
it can be found in 3 places:
  • Under the figure menu
  • In the setup room
  • In the fittting room.
PhilC ( ) posted Sun, 04 May 2014 at 8:19 PM
Poser 9 has Wardrobe Wizard that can do the job provided that you have the V4 support files.
moriador ( ) posted Sun, 04 May 2014 at 11:22 PM · edited Sun, 04 May 2014 at 11:24 PM
Quote - Poser 9 has Wardrobe Wizard that can do the job provided that you have the V4 support files.
I believe this would be the least expensive route to take.
Edit: I do have a question for you, Phil. For crossfigure conversions (e.g. V2 to V4) do you need both the 'to' and 'from' support files? (I think I've got most of the ones I need anyway, but I'd like to know. I might need more of them.)
PhilC ( ) posted Mon, 05 May 2014 at 4:07 AM
Yes you need the support files for both the to and from figure. SheFreak is I believe a morph off V4 so you just need V4.
moriador ( ) posted Mon, 05 May 2014 at 6:19 AM
Quote - Yes you need the support files for both the to and from figure. SheFreak is I believe a morph off V4 so you just need V4.
That makes sense. Thank you. :)
EClark1894 ( ) posted Mon, 05 May 2014 at 7:24 AM
In case the OP needs to know how, load V4 and apply the She Freak morph.
Now, open Wardrobe wizard and have it analyze the she Freak fullbody morph you applied.
And that's basically it. WW will now add the She Freak morphs to what ever clothing item you convert for V4, including her old stuff.
