Mon, Nov 25, 10:28 PM CST
Subject: Genesis - Hanging Poser
jarm ( ) posted Tue, 13 May 2014 at 1:39 PM · edited Mon, 25 November 2024 at 10:25 PM
Decided to give Genesis another go, however I seem to have hit a bit of a block.  Normally when spinning morph dials poser hangs.  It's not recoverable either.
Didn't know if anybody had any obvious solutions or tips to improve things.  PP2014, 16gb of RAM and six core processer. Using latest DSON as far as I know (redownloaded from Daz).  It may just be that's how Genesis is in Poser, but it'd be nice to hear some hints and tips from those using it more than I.
best wishes
Jody
wimvdb ( ) posted Tue, 13 May 2014 at 2:39 PM
Lower the subdivision level in the figure to 0. It can be found in the body properties of the figure. That will work if you have one or 2 genesis figures. If you have more, performance will drop significantly
hborre ( ) posted Tue, 13 May 2014 at 3:47 PM
You can lower the Sub-D to zero through the DSON script also.
jarm ( ) posted Tue, 13 May 2014 at 3:47 PM
OK, will give that a go, thanks
moriador ( ) posted Tue, 13 May 2014 at 8:28 PM
I believe, if you use the dials in the figure body, you can lower the subdivision to -1. There does seem to be a difference between -1 and 0. It's possible I'm imagining that difference, but worth a try, just to see if it helps you, too.
RorrKonn ( ) posted Tue, 13 May 2014 at 11:39 PM
what I herd other say
don't spend dials ,type in #'s
only have one mesh in a scene at a time
jarm ( ) posted Wed, 14 May 2014 at 3:13 AM
Haven't had hang since reducing subdivison, I'm also typing rather than spinning.  Maybe I was just being too rough on the poor imported thing :-)
hborre ( ) posted Wed, 14 May 2014 at 8:13 AM
When setting the sub-d to zero using DSON script, the value on the parameter dial does become -1.
And, actually, you would be better off setting the skinning method to Poser Unimesh and increasing the sub-d to 1 or higher for render only.  Save the character back to the Library as a CR2 to decrease the loading time into a scene.
Male_M3dia ( ) posted Wed, 14 May 2014 at 9:16 AM
Quote - And, actually, you would be better off setting the skinning method to Poser Unimesh and increasing the sub-d to 1 or higher for render only.  Save the character back to the Library as a CR2 to decrease the loading time into a scene.
This depends on what morphs you are using. Poser's subdivision is missing the edge weighted creasing from the Pixar spec, so more detailed morphs lose a lot of their details when you switch over. HD morphs do not work with Poser's subdivision due to this.
hborre ( ) posted Wed, 14 May 2014 at 10:40 AM
That's a shame. Glad you pointed that out; it saves a lot of grief later on.
