Sat, Nov 9, 6:17 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 3:34 pm)
Subject: talk designer
darquevision ( ) posted Tue, 20 May 2014 at 8:35 AM · edited Wed, 06 November 2024 at 11:22 PM
so poser switched its talk feature from mimic(which for my needs was just fine) to talk designer and it needs the wav to be mono 22050 rate and all that. however i think mine crashed or something. it did work on some files, in the past in talk designer. so i made some new ones and thought it had the same specs but it reads "this audio format is not recognized by poser". so i thought it might be me so i tried one i knew worked before, and got the same error message. so i figured i would try one of the "default" wavs poser has, and got the same error message.(sorry that was a little long winded)
any suggestions?
thanks in advance
Helos ( ) posted Tue, 20 May 2014 at 9:37 AM
Which version of Poser, Mac or PC and which OS?
darquevision ( ) posted Tue, 20 May 2014 at 5:01 PM
pc poserpro 2009
parkdalegardener ( ) posted Wed, 21 May 2014 at 7:13 AM
Check to be sure your audio files are uncompressed wav files sampled at 22050. Poser's manual is a little incomplete and incorrect when it comes to Talk Designer for some reason.
Looking at the supplied files in PP2012, I don't have PP2010 on this machine and I've never owned P9; I can see that the audio is sampled at 44100 uncompressed. Somewhere Talk Designer changed in the sample rate it can use. I just ran a PP2012 sample through PP2014. It crashed with the same error as you describe. Drop the sampling rate and previous included samples work just fine.
