Thu, Feb 13, 9:33 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:49 pm)
Subject: Dawn Update
arrow1 ( ) posted Wed, 22 January 2014 at 3:52 PM · edited Thu, 13 February 2025 at 4:40 PM
I got am email this mornining from HiveWire 3D to say there is a free SR1 update for Dawn available. Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
ghostship2 ( ) posted Thu, 23 January 2014 at 10:00 AM
I haven't downloaded it yet but no info was given that anything was actualy updated other than they added some new texture maps.
WandW ( ) posted Thu, 23 January 2014 at 11:35 AM
Here's what's updated:
Poser Files - Main ZIP
DAZ Studio Files - Main ZIP
DAZ Studio Files - GlamPonytail
DAZ Studio & Poser Files - String Bikini Textures (2 of 2)
DAZ Studio & Poser Files - String Bikini Textures (1 of 2)
DAZ Studio & Poser Files - Main Textures
willyb53 ( ) posted Thu, 23 January 2014 at 1:12 PM
from the hivewire3d forums:
  • Dawn SR1 List of changes:
*Poser:
*Removed conforming end points
*Fixed IK ordering
*Remove "animatedOrigin" from base and moved it to Base INJ morph file.
*Added UV morph fix for eyes to morph INJ & REM files
*Turned off "Match End Points when Conforming" for all Clothing in Base and Starter Stacks.
*Fixed weights on teeth for side-side & twist
*Created new Dawn Dev rig with SR1 changes
*Removed unused tongue influences from morphs in the PMD
  • Moved INJ file readScript to libraries/HiveWire 3D folder and added to morph INJ file for Base and Starter morphs.
    *Added Blank Base morph to morph INJ file as work around for "last morph injection resets when posed" bug in Poser
    *Fixed Everyday poses to not relocate Body
    *Added Bonus Bikini textures to Dawn Base
*DAZ Studio:
*Added metadata to all Base and Starter stack products
*Fixed displacements not loading for eyebrows
*Fixed Face bump maps to apply to whole face.
*Added UV morph fix for eyes to Base morphs
*Created Base Projection Templates for Auto fit and Transfer
Bill
AetherDream ( ) posted Thu, 23 January 2014 at 11:48 PM
I was very glad to see the eye fix. It was the one thing that I really wanted to see fixed.
"People who attempt define what art is or is not, are not artists"---Luminescence
ghostship2 ( ) posted Fri, 24 January 2014 at 7:38 AM
Quote - I was very glad to see the eye fix. It was the one thing that I really wanted to see fixed.
Yep! that was the reason I did not use Dawn at all. could not get the eyes to look real at all with the way they were modeled and maped.
ghostship2 ( ) posted Mon, 27 January 2014 at 12:37 PM
I just downloaded and installed SR1. Opened Zip and did a copy/replace old files . Still same problem with Dawn's eyes unless I did something wrong when installing the new files.
ghostship2 ( ) posted Mon, 27 January 2014 at 12:44 PM
could not see any UV morph fix pose file in Hivewire3d/Dawn/morphs. Not sure how this morph is implemented.
raven ( ) posted Mon, 27 January 2014 at 2:43 PM
Did you just redownload the files? If you did they aren't the updated ones. You have to add DawnSR1 to your cart in the store and checkout to get the new files.
ghostship2 ( ) posted Mon, 27 January 2014 at 3:50 PM
Quote - Did you just redownload the files? If you did they aren't the updated ones. You have to add DawnSR1 to your cart in the store and checkout to get the new files.
Yes I added SR1 to my cart and downloaded that.
I am having better results with figure skinning set to Poser Unimesh and setting her subdivision level set to 1 for rendering. but otherwise looks like no change at all with SR1.
meatSim ( ) posted Mon, 27 January 2014 at 9:17 PM
I may be wrong.. I've been too busy to get the SR downloaded and installed.  But I dont think the eye fix loads by default, it needs to be dialed in.  The reason being that using non-fixed textures with the fixed eye can look pretty bad.  The actual Dial for it may have OOT in the name.. not sure, perhaps someone who has the release version of the SR installed can point to the exact location and name
or read the readme... I havent had the time to do that either :P
ghostship2 ( ) posted Mon, 27 January 2014 at 9:23 PM
Quote - I may be wrong.. I've been too busy to get the SR downloaded and installed.  But I dont think the eye fix loads by default, it needs to be dialed in.  The reason being that using non-fixed textures with the fixed eye can look pretty bad.  The actual Dial for it may have OOT in the name.. not sure, perhaps someone who has the release version of the SR installed can point to the exact location and name
I could have missed something but I checked both for a morph injection and found none in the pose folder. I then loaded the starter morphs and base morphs. no dials from either of these on the L or R eyeballs.
RedPhantom ( ) posted Tue, 28 January 2014 at 7:06 AM
Site Admin Online Now!
The eye fix is part of the DawnBase morphs. It is then a dial under body (rather than head) set at 0.
raven ( ) posted Tue, 28 January 2014 at 7:12 AM
Here's where it appears for me on the parameters palette.
Here's what the SR1 readme says about it:
2-The UV morph fix has been turned OFF by default, in order to not have it adversely affect current Dawn textures that were not created using it.  You can turn this morph on by going to the Parameters tab in Poser or DAZ Studio, selecting Dawn's body and dialing OOT-MorphsDawnIrisSmooth to 100% or anywhere in between 0 (default) and 100% as desired.
Note that this morph will appear in DAZ Studio when the files are installed, and in Poser when you apply the Base Morph INJ.
ghostship2 ( ) posted Tue, 28 January 2014 at 10:19 AM
This gives me hope! thanks for finding that.
infinity10 ( ) posted Sun, 25 May 2014 at 3:12 AM
I have trouble logging into the Hivewire Forums, despite resetting passwords blah blah. So am going to ask here instead.
Which of the original Dawn conforming clothing and character textures can I use with Dawn SR1 ?
Eternal Hobbyist
tparo ( ) posted Sun, 25 May 2014 at 3:42 AM
As far as I'm aware you should be able to use all of the original clothing etc.
I don't use Poser much if at all really so I don't know if the Poser version of SR1 is different but in DS I haven't had trouble with anything.
All the Hivewire stuff does work I know.
As to problems with logging into Hivewire, try contacting Alisa over there if you can't I can direct her here for you and she'll sort out your problems.
infinity10 ( ) posted Sun, 25 May 2014 at 7:02 AM · edited Sun, 25 May 2014 at 7:03 AM
Thanks for the info. I managed to log in finally. They seem to be fixing some issues with their forum system.
Eternal Hobbyist
AetherDream ( ) posted Sun, 25 May 2014 at 9:15 AM
Quote - I have trouble logging into the Hivewire Forums, despite resetting passwords blah blah. So am going to ask here instead.
I have have not had any problems using any of the things I purchased. All character textures are working the same.
