Mon, Nov 25, 10:10 PM CST
Subject: Need to reinstall Poser Pro 2014 due to windows 7 failure, I cannot find my down
rowlando ( ) posted Tue, 27 May 2014 at 2:04 AM · edited Mon, 25 November 2024 at 10:06 PM
I have pp2014 working but its missing some start up files that a new install would fix I think.  I do not have my files for orriginal install nor can I download from smith micro because I did not buy longer download availabilty ( thats a crap upsell) anyhow I have a problem.
I have my code for it and thought I saved the install files with it but alas the file only contains a text doc with my code in it.
The files should be on my PC somewhere just no Idea what the files are named or how to find them.
Any help woud be great thanks
Rowlando
Seek what you can never loose
phil_lawson ( ) posted Tue, 27 May 2014 at 3:24 AM
Try searching your machine's hard drives for Poser.exe if its Windows. Ifits Mac I'll have to tell you later.
rowlando ( ) posted Tue, 27 May 2014 at 3:33 AM
Thanks phil just wondering what the names of the orriginal poser install files would be named or are you saying they would be poser.exe
Cheers Rowlando
rowlando ( ) posted Tue, 27 May 2014 at 3:49 AM
All I have found so far is
Install_Poser_Pro_2014_Win_SR__2.2.exe
I don't think this is actual program just the SR update I think?
hornet3d ( ) posted Tue, 27 May 2014 at 4:00 AM
The file name I have is 'Install Poser Pro 2014 (10.0.0.24941)' but I used the Download Manager so it is in a folder marked 'SmithMicroDLM/Installed'.  Unfortunately I cannot tell you the exact location as I back up all my install and content files to a seperate hard drive, with Poser I go back as far as Poser 5
rowlando ( ) posted Tue, 27 May 2014 at 4:27 AM
Thanks hornet3d  I also downloaded my PP2014 so I will serch for the names you have given.
I find it strange I have back to Poser 6 and I upgraded each time the only ones missing are PP2014 but the folder has the serial only text file left.
Cheers
hornet3d ( ) posted Tue, 27 May 2014 at 5:05 AM
Quote - Thanks hornet3d  I also downloaded my PP2014 so I will serch for the names you have given.
Cheers
If I remember rightly, I think Poser 2014 was the first time they used the Download Manager so the fact that this is the only file missing may be related in some way.
rowlando ( ) posted Tue, 27 May 2014 at 5:06 AM
I am not having any success of finding these files its really frustrating. I am going to bed maybe I will have better succes tomorrow
Cheers Rowlando
hornet3d ( ) posted Tue, 27 May 2014 at 5:07 AM
Cheers
basicwiz ( ) posted Tue, 27 May 2014 at 9:32 AM
Although you probably don't want to do it, Smith Micro will sell you the download extention at any time.
seachnasaigh ( ) posted Tue, 27 May 2014 at 9:44 AM · edited Tue, 27 May 2014 at 9:47 AM
Look in C:users{username}SmithMicroDLMdownloadsinstalled  on Win7.  Might get lucky, might not.
bevans84 ( ) posted Tue, 27 May 2014 at 10:07 AM
Do a hard drive search for SmithMicroDLM
It should be there somewhere, unless it's been deleted.
hornet3d ( ) posted Tue, 27 May 2014 at 10:32 AM
Quote - Look in C:users{username}SmithMicroDLMdownloadsinstalled  on Win7.  Might get lucky, might not.
You could well be right, I hope you are for the OPs sake.  I found a second copy of SmithMicroDLM (I have one copy on by backup drive) in the Download Folder on my D drive but then I probably downloaded it there as I keep all downloads and most programs on my D drive as the C drive is an SSD.
WandW ( ) posted Tue, 27 May 2014 at 11:35 AM · edited Tue, 27 May 2014 at 11:38 AM
I just tried the address in my confirmation email and it still works; I purchased it last May, so it's been over a year.  The file name indicates that it's post-SR3.1.  It is SmithMicro-DownloadManager-Win_1.0.3.26732.exe
If you don't have the email, and have Poser Debut, the update page for it downloads the Download Manager.  (you will need the debut serial number) You could then try entering the PP2014 serial after installing it and see if it will download 2014...
rowlando ( ) posted Tue, 27 May 2014 at 9:42 PM
Hey all thanks so much I think its solved:
I found a file as per hornet3d suggests under user name then I found the  download manager file. Run the file to install download manager it asked for my serial it then installed and I then had to install the serial again and it took me to all the downloads to install for PP2014 so I am now in the process of doing it.
what a relief.
My windows 7 system crashed and smashed. I got a new hd put in but was able to access the old drive and see all my installed files. But needed to reinstall programs on the new HD. This is what I have been doing.
Thanks so much for the help Rowlando
