The file name I have is 'Install Poser Pro 2014 (10.0.0.24941)' but I used the Download Manager so it is in a folder marked 'SmithMicroDLM/Installed'. Unfortunately I cannot tell you the exact location as I back up all my install and content files to a seperate hard drive, with Poser I go back as far as Poser 5
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
Quote - Thanks hornet3d I also downloaded my PP2014 so I will serch for the names you have given.
I find it strange I have back to Poser 6 and I upgraded each time the only ones missing are PP2014 but the folder has the serial only text file left.
Cheers
If I remember rightly, I think Poser 2014 was the first time they used the Download Manager so the fact that this is the only file missing may be related in some way.
Cheers
Quote - Look in C:users{username}SmithMicroDLMdownloadsinstalled on Win7. Might get lucky, might not.
You could well be right, I hope you are for the OPs sake. I found a second copy of SmithMicroDLM (I have one copy on by backup drive) in the Download Folder on my D drive but then I probably downloaded it there as I keep all downloads and most programs on my D drive as the C drive is an SSD.
I just tried the address in my confirmation email and it still works; I purchased it last May, so it's been over a year. The file name indicates that it's post-SR3.1. It is SmithMicro-DownloadManager-Win_1.0.3.26732.exe
If you don't have the email, and have Poser Debut, the update page for it downloads the Download Manager. (you will need the debut serial number) You could then try entering the PP2014 serial after installing it and see if it will download 2014...
"Oh - the manual says that? I have never read the manual - this must be why."Hey all thanks so much I think its solved:
I found a file as per hornet3d suggests under user name then I found the download manager file. Run the file to install download manager it asked for my serial it then installed and I then had to install the serial again and it took me to all the downloads to install for PP2014 so I am now in the process of doing it.
what a relief.
My windows 7 system crashed and smashed. I got a new hd put in but was able to access the old drive and see all my installed files. But needed to reinstall programs on the new HD. This is what I have been doing.
Thanks so much for the help Rowlando
Seek what you can never loose
I have pp2014 working but its missing some start up files that a new install would fix I think. I do not have my files for orriginal install nor can I download from smith micro because I did not buy longer download availabilty ( thats a crap upsell) anyhow I have a problem.
I have my code for it and thought I saved the install files with it but alas the file only contains a text doc with my code in it.
The files should be on my PC somewhere just no Idea what the files are named or how to find them.
Any help woud be great thanks
Rowlando
