Sat, Feb 8, 12:22 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 8:53 pm)
Subject: Right click freezes Library window
ElZagna ( ) posted Mon, 02 June 2014 at 11:06 PM · edited Sat, 08 February 2025 at 12:11 AM
I recently noticed that when I right click inside the Library window the Library windows freezes. I can move the window around, and close and reopen it but nothing inside the window is accessable. Sometimes it unhangs after 20 or 30 seconds but sometimes I have to close Poser and reopen.
I've submitted an incident report to SM, but does anyone else have this problem?
OS: Windows 10 64-bit, Poser: 10
hborre ( ) posted Tue, 03 June 2014 at 8:36 AM
Haven't seen anything unusual in PP2014 32-bit; are you current with all the SRs?  And has anything changed or updated recently?
ElZagna ( ) posted Tue, 03 June 2014 at 10:28 AM
I recently upgraded from Windows Vista to 8.1, which required me to install some Poser 9 upgrades, but everything should be current.
honzu ( ) posted Tue, 03 June 2014 at 2:30 PM · edited Tue, 03 June 2014 at 2:30 PM
Same freezing here. PPro2014 64bit / W7 64bit
Alt-Tab to another program and switching back solves the freeze sometimes
Vaskania ( ) posted Tue, 03 June 2014 at 2:46 PM
Are you using the internal or external library? Try switching to the other in the preferences.
-----sig-----
Daz, Blender, Affinity, Substance, Unity, Python, C#
ElZagna ( ) posted Tue, 03 June 2014 at 3:27 PM
Hmmm... Yep, it looks like just going to another app will unfreeze it.
Vaskania, what internal and external libraries are you talking about? Do you mean the Poser default library?
Vaskania ( ) posted Tue, 03 June 2014 at 5:31 PM · edited Tue, 03 June 2014 at 5:32 PM
Yes. Poser's library can run on two modes.. internal (flash based.. or IE.. I forget) and external (adobe air based). Sometimes if you have issues with one, switching to the other may help.
Edit > General Preferences > Library tab.
Just note that external mode can't be docked and is used as a second window.
-----sig-----
hborre ( ) posted Tue, 03 June 2014 at 6:27 PM
Adobe Flash does not work well in 64-bit, use Adobe Air instead for the Library.
ElZagna ( ) posted Tue, 03 June 2014 at 8:23 PM
I am running Poser 9 in Windows 8.1 32-bit. The two modes aren't an option for me.
Vaskania ( ) posted Wed, 04 June 2014 at 4:16 AM
Take a read through this thread: http://forum.runtimedna.com/showthread.php?85917-External-Library-for-Poser-Pro-2012
The user was also experiencing issues with Windows 8 and the Poser library.
-----sig-----
hborre ( ) posted Wed, 04 June 2014 at 9:27 AM
Quote - I am running Poser 9 in Windows 8.1 32-bit. The two modes aren't an option for me.
Oops!  Entirely missed that point.
ElZagna ( ) posted Wed, 04 June 2014 at 10:00 AM
Quote - Same freezing here. PPro2014 64bit / W7 64bit
Since you have Poer Pro, have you tried the suggestions about using the external (Air) library?
honzu ( ) posted Wed, 04 June 2014 at 12:03 PM
yes, that "fixed" it.
